Leaking Chimney - Building & Construction - DIY Chatroom Home Improvement Forum
Old 01-09-2010, 02:22 PM   #1
Leaking Chimney
Hi Again!
I am renovating my basement in a 1940's house. The Chimney is no longer being used as I switched to a high-efficiency furnace. The problem is that water leaks out of the bottom chimney "duct", and into my basement. This only happens once a year when the heavy snow collected over the winter melts over a week. I have a strong inkling that it is leaking in from the bottom of the chimney (not along the stack since it only leaks during the snow melt). How can I repair this problem?
Dom_Reno_Man is offline   Reply With Quote
water leaking through brick chimney quigleybmd Concrete, Stone & Masonry 45 02-26-2013 04:26 PM
Attic leaking from Chimney? Fred123 Building & Construction 2 10-08-2009 05:00 PM
Roof leaking by Chimney, No Flashing twilightcall Roofing/Siding 2 07-30-2008 04:40 PM
Chimney leaking and flooding viper9092 General DIY Discussions 2 07-25-2008 05:34 PM
Looks like leaking around the chimney - roofer says it is the chimney itself Salvatorparadise Roofing/Siding 6 03-07-2008 03:12 PM
