Leaking Basement Wall - Help - Building & Construction - Page 2 - DIY Chatroom Home Improvement Forum
Old 09-16-2009, 07:39 AM   #16
Question
Sonneborn
It is just a shinkage crack, maybe 1/16th wide at the most but from top to the slab, it does not meet in the middle kind of goes the stops then picks up a few inches over. It is in the middle of a long straight wall. BASF has like 25 diff. Sonneborn products what is the "gray" stuff called?
You use the pvc miradrain dimpleboard bellow grade to create a air void to let the crack area drain out correct? I would think the roofing tar would clog it up??
shortlid is offline   Reply With Quote
Old 09-16-2009, 07:41 AM   #17
Rewards Points: 3,614
roofing cement would work as well,,, the coatings prevent water from entering that particular crk ONLY !
Old 09-16-2009, 07:57 AM   #18
Only leaking at the cracks
The basement only leaks at that crack, and at another shrinkage crack where the foundation steps down for the framing of the walk out on the other side of the house. I will dig both out bellow grade and apply the roofing cement and see how it goes! Thanks again!
Basement Wall Mortar rory535 Building & Construction 16 08-06-2009 09:39 AM
"Frost" appearing on wall in basement Pretty_Suite_Recording Building & Construction 8 06-15-2008 09:58 PM
damp basement wall. itguru Building & Construction 7 12-16-2007 05:02 PM
Marrying a sloping stone wall to a cinder block wall. mrdol Landscaping & Lawn Care 1 11-09-2007 04:08 PM
Dirt along wall in basement? Beren General DIY Discussions 20 07-01-2007 03:53 PM
