Laying Concrete - Building & Construction - DIY Chatroom Home Improvement Forum
Old 08-01-2009, 08:41 AM   #1
Laying concrete
on that bbq pit that was layed with bricks how many bags of concrete was used and how many bricks the slab is 50 x 50
tinkerbell2 is offline   Reply With Quote
Old 08-01-2009, 06:51 PM   #2
Rewards Points: 1,016
Which BBQ are you reffering too? And is the 50 x 50 in inches, feet, or other?
Old 08-01-2009, 07:53 PM   #3
slab
Yes 4inches deep by 50" x 50 " this is the website http://www.extremehowto.com/xh/artic...id=60223#other
Old 08-01-2009, 08:39 PM   #4
Looks like a very nice project - very doable. A google found this concrete calculator that I think will answer you question. http://www.concretenetwork.com/concr...calculator.htm
I see the referenced article recommends 6" thickness and fiberglass reinforced concrete. I would agree with the 6" thinkness - this would ensure the slab would handle the weight of the BBQ and last well. I have no experience with the fiberglass reinforced concrete - I would put in wire mesh myself. I imagine someone will come along and be able to speak to the fiberglass reinforced concrete.
You might want to consider readymix concrete rather than bags. Several sources now for self-tow setups suiteable for smaller projects. You would come out with a better and stronger concrete mix and less work.
Old 08-02-2009, 06:18 PM   #5
Rewards Points: 3,614
for 13 - 140 bags of apron store conc mix ? ? ? f/g reinforc'd is ok but we'd use wire mesh 'cause its on hand,,, try polypropylene or polyesther fibers instead.
Old 08-02-2009, 08:26 PM   #6
The area is only 50 inches by 50 inches and 6 inches deep
Old 08-03-2009, 05:38 AM   #7
understood from above,,, iirc, ea bag of conc mix yields .67cu ft or, roughly, 13bags of apron store stuff
Tags
mike
How To Keep Your Concrete Mixer Driver Happy Mort How To Guides 38 02-12-2014 06:25 PM
Is it necessary to get rid of paint on concrete before laying ceramic tiles? yummy mummy Flooring 41 03-17-2013 09:46 AM
Laying dura ceramic tiles on concrete monte Flooring 25 03-11-2013 09:31 PM
Pulling up tile and laying bamboo on concrete kdhughes Flooring 2 07-19-2007 11:11 PM
