Lateral Bracing With Short Deck Posts - Building & Construction - DIY Chatroom Home Improvement Forum
Old 05-30-2017, 07:56 PM   #1
Rewards Points: 170
lateral bracing with short deck posts
Building my new deck atop concrete piers and I've come to the first couple potential issues I didn't account for. From where I need the decking to hit against the house under the door sill, to the top of my post bases leaves me 31". By my calculations for 2x6 decking, 2x10 joists, and 2x10 beams, I should have about 11" for some squatty deck posts.
First, this makes the underneath virtually inaccessible with less than a foot of crawl space. This may be why the previous deck had the joist and beam layer collapsed into one. I really don't want to build it that way. Is this a problem? Or perhaps a code violation? I can't think of a reason I would ever need to get under there, but I'd certainly hate to have to rip my decking off to get access.
Second, lateral bracing. I assume having shorter posts reduces (and i'm ONLY assuming) racking. But if not, is there a good way to add lateral bracing to posts this short?
RETALS is offline   Reply With Quote
Old 05-31-2017, 06:09 AM   #2
MEASURE ONCE, CUT TWICE
123pugsy's Avatar
Rewards Points: 1,438
Re: lateral bracing with short deck posts
Is the span small enough for 2x8 joists?
If it's tied to the house, no lateral bracing required for sure.
Pugsy...my project: http://www.diychatroom.com/f49/total...storey-276978/
123pugsy is offline   Reply With Quote
Old 05-31-2017, 06:44 AM   #3
Lay out your materials and measure them. Set aside 2x10s for beams and joists for widths that are close. Take your biggest measurement, add them up, and make sure you don't add mistakes later - such as uneven lumbers in a beam, joists not even with ledger, lumbers not sitting on beams, posts, etc. Add 1/8" to the numbers you need.
carpdad is offline   Reply With Quote
Old 05-31-2017, 07:06 AM   #4
Rewards Points: 170
I think the longest span is 9'. But if I switch to 2x8 I'm still only gaining 2" back. Will that even gain me anything? It is a free standing deck.
Old 05-31-2017, 07:26 AM   #5
123pugsy's Avatar
Only if you need to really crawl under. 2" is better than nothing.
My front porch is like this.
I don't see any reason to go under there.
Frame it up and check if you need bracing for it.
You'll feel if it's stiff or not by standing on top and try swaying it back and forth.
The Following User Says Thank You to 123pugsy For This Useful Post:
RETALS (05-31-2017)
Deck Staining Nightmare steven994 Painting 7 06-14-2017 05:56 AM
Concrete Footing and beams for suspended deck johndrew Concrete, Stone & Masonry 6 09-27-2015 09:59 PM
Surface Mounted Deck Post Problem sore thumb Building & Construction 17 04-06-2013 06:45 PM
Deck project - Shim beams or joists? jcims Carpentry 1 08-08-2009 09:02 PM
UGH! just realized one of my deck posts is cut too short nasdaqer Carpentry 8 06-19-2007 08:26 AM
