Laneway Ditch Retaining Wall.... - Building & Construction - DIY Chatroom Home Improvement Forum
Like Tree1Likes
  • 1 Post By Nealtw
Old 05-23-2018, 09:57 AM   #1
NorPlan's Avatar
Rewards Points: 256
Laneway Retaining Wall over Ditch by the Township Road needs Replacing.. It's presently of a wood construction.. The Plan is to use the existing wall as a Form on Oneside and Dig a Trench and Pour Concrete on the Inside.. Need to Calculate how much cement will be needed say 18" Thick by 13' Long by 4' High... The Cost Factor is whether to (1) Truck in the Ready Mixed Cement or (2) Required amount of Bags and Mix on site.. Thoughts & Opinions Appreciated, Cheers Thanks
NorPlan is offline   Reply With Quote
Old 05-23-2018, 10:08 AM   #2
retired framer
Rewards Points: 4,674
Re: Laneway Ditch Retaining Wall....
1.5x4x13 / 27= yards x 2000lbs/ 60 lb bags.
Old 05-23-2018, 12:46 PM   #3
NorPlan's Avatar
Rewards Points: 256
If my Math is Right...lol... 96 + Bags required ??
Old 05-23-2018, 12:56 PM   #4
Super Moderator
joed's Avatar
Rewards Points: 30,136
2.8 yards call it 3.
That would be enough for a truck order.
Old 05-23-2018, 12:56 PM   #5
retired framer
But that is not how I would build a retaining wall, dig the trench and pour a footing 18+ wide by 12" high with rebar hooks and then pour a 8" thick wall on the outside edge of the footing with drain ports and back fill with gravel next to the wall and dirt behind that.
The Following User Says Thank You to Nealtw For This Useful Post:
NorPlan (05-23-2018)
Old 05-23-2018, 01:10 PM   #6
NorPlan's Avatar
Rewards Points: 256
Thanks (Nealtw) for the Comeback... Absolutely, Planning on putting a number of 10' T-Bars down into the ground...
Old 05-23-2018, 01:19 PM   #7
retired framer
T bars????
Msradell likes this.
Replacing retaining wall in front of old wall - options? dc300m01 Landscaping & Lawn Care 2 07-04-2016 10:43 PM
Replace Collapsed 4' Retaining Wall With Dirt Slope? gunner666 General DIY Discussions 4 08-07-2014 11:09 PM
Please help with retaining wall / patio issue that has arisen. coderguy Landscaping & Lawn Care 3 05-26-2012 05:45 PM
Retaining wall combining concrete blocks and PT lumber JEL Landscaping & Lawn Care 1 04-06-2012 09:39 PM
Low Retaining Wall cibula11 Landscaping & Lawn Care 3 07-29-2007 01:02 AM
