Knots For Layout Lines - Building & Construction - DIY Chatroom Home Improvement Forum
Like Tree6Likes
  • 2 Post By Nealtw
  • 1 Post By trainguy
  • 3 Post By trainguy
Old 09-25-2019, 10:06 PM   #1
Rewards Points: 28
Knots for Layout Lines
So this is a total noob question but what the heck. I may sound like an idiot for asking it but since I am hoping to learn, here goes.
I've seen countless instances where people have installed string/layout lines for establishing straight lines for fence posts, foundation edges, etc. I have done this myself from time to time and I have always struggled with tying the string at the 2nd end in order to make the line taught (I've gotten creative knowing that my solution was not what the pro's typically do). What is the best way to do this? Perhaps the name of a common knot is the best explanation and from there I can find out how to tie it from a book of knots (I'm not much of a Boy Scout unfortunately).
Thanks in advance for your advice!
Jimmy
trainguy is offline   Reply With Quote
Old 09-26-2019, 02:54 AM   #2
retired framer
Rewards Points: 1,690
Re: Knots for Layout Lines
123pugsy and lenaitch like this.
Do not use flat bottom gables with scissor trusses.
Nealtw is offline   Reply With Quote
Old 09-26-2019, 05:11 AM   #3
Rewards Points: 7,112
First, start with masons string, it stretches and once pulled and tied it will not sag.
To tie the second end I often just wrap it multiple times around that nail and then half hitch it with a loop so I can pull the lose end to release it like a shoe lace.
You can also back up a couple of feet and tie a loop, double the string and tie the double into a knot leaving a one to two inch loop. Then around your final nail and back through that loop and you can cinch it up and half hitch it to hold.
Now, as for actual names for knots, I just used what I have heard over the years, not a navy guy or mason or boy scout.
Bud
I volunteer my help and opinions, but you are responsible for what YOU choose to do with that information.
Bud9051 is offline   Reply With Quote
Old 09-26-2019, 10:45 AM   #4
Ole Wood Worker
BigJim's Avatar
Rewards Points: 286
I did my string like the video except I used two fingers instead of just one.
New members: Please consider adding your location to your profile.
Lawyers believe a man is innocent until proven broke.
If you do what you've always done, you'll get what you've always got.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is offline   Reply With Quote
Old 09-26-2019, 11:43 PM   #5
Rewards Points: 28
Originally Posted by Nealtw View Post
Wow, easy peasy! Nice! Thanks for the video explanation!
Nealtw likes this.
Old 09-27-2019, 05:04 PM   #6
Usually Confused
lenaitch's Avatar
Rewards Points: 266
That's cool. Kinda sorta like a (modified) timber hitch.
_________________________________________
Sic Itur at Astra
lenaitch is offline   Reply With Quote
Old 09-27-2019, 11:33 PM   #7
Rewards Points: 28
All-
By complete accident, I found this video. Totally sweet!
123pugsy, lenaitch and Nealtw like this.
