Kneewall Insulation/sealing Question - Building & Construction - DIY Chatroom Home Improvement Forum
Old 12-11-2010, 08:17 PM   #1
kneewall insulation/sealing question
I have some kneewall that's insulated with R-13 Batts. The back of the kneewall is not sealed. I'm been thinking about sealing it for a while. The reason that I hesitated is because it's a lot of work and quite some investment. I keep thinking if it worth it.
I used a infrared thermometer to measure the inside of the kneewall and discovered it's about the same temperature as other segments of interior wall (that's not kneewall). Does this mean that it may not be necessary to work on the kneewall, since it is not worth off then other walls?
deerhunter is offline   Reply With Quote
Old 12-14-2010, 10:29 PM   #2
Registered User
Rewards Points: 526
That means the heater in the room is warming the walls. Loss of heat at the knee wall may be pronounced and rapid due to the minimal insulation being exposed to wind-washing there. Block the air above and below in the joist bays, right up to the baffles w. f.g. in plastic garbage bags: http://www.simplesavings.coop/simple...ee%20walls.pdf
Gary
DRIcore question trailblazer1229 Flooring 0 02-24-2010 09:25 AM
3 Phase meter socket question a320200 Electrical 4 12-11-2009 12:45 AM
An unasked question is the only dumb question jackie treehorn Kitchen & Bath Remodeling 1 09-20-2009 08:24 PM
A question about water preassure. reasonforseason Plumbing 5 04-14-2009 04:36 PM
Basement Renovation Question KUIPORNG Remodeling 234 08-26-2008 08:19 AM
