Keeping Existing Features Of A Building During Demolition Process - Building & Construction - DIY Chatroom Home Improvement Forum
Old 01-26-2019, 10:09 AM   #1
Rewards Points: 12
Keeping existing features of a building during demolition process
I'm planning a demolition of a dilapidated 1200 sq ft 2 storey structure attached to the rear of my building. We are planning to replace this structure with a new one. There is a brick wall on the ground level which is itself on top of a rubble foundation (built circa 1900 ), that my partner would like to retain and incorporate into the new structure. I'm wondering which would be less complicated/expensive:
Preserve and shore up the existing wall/foundation during the demolition/reconstruction process?
or
Tear down the wall and re-use the bricks to build a wall/features within the new structure?
Background info: The bricks are unique to the area. They were made in a local foundry back in the 19th century and have unique character. They are also useful whenever we need to replace or add to the main building which is entirely built of this brick.
Rob Hellier is offline   Reply With Quote
Old 01-26-2019, 11:11 AM   #2
Rewards Points: 4,330
Re: Keeping existing features of a building during demolition process
Odds are it will be more expensive to keep and incorporate something like this.
Will you be building the new structure or hiring done? If the latter, get a few contractors out to bid the job both ways.
stick\shift is offline   Reply With Quote
Old 01-26-2019, 11:27 AM   #3
Rewards Points: 12
Good idea to discuss/price options with a demolitions contractor. Thanks.
Old 01-26-2019, 11:43 AM   #4
Naildriver
chandler48's Avatar
Rewards Points: 966
Keep in mind you have two threads on the same building. It will get confusing, eventually. Always best to keep one train of thought going.
Larry......
Half of Communications is Listening, and You can't Listen with your Mouth.
chandler48 is online now   Reply With Quote
Old 01-26-2019, 12:09 PM   #5
Oso954's Avatar
Rewards Points: 294
I would discuss the options with a building contractor, not a pure demolition contractor.
Having a brick wall on an old rubble foundation can compromise/cause problems/increase costs of the new structure. If it does, you want to discover those impacts now, not when you think you are ready to start construction of the building.
Oso954 is online now   Reply With Quote
Old 01-26-2019, 01:10 PM   #6
Rewards Points: 254
Remodeling/restoring anything old and not in line with remotely "modern" such as standard footing/foundation will cost lots and lots of money. If your partner wants exposed brick, try to save the bricks and return them later.
carpdad is offline   Reply With Quote
Building A Tin Roof Over Existing Deck TheBug Building & Construction 8 06-13-2009 07:26 PM
Building a Loft in an existing structure kelukens Building & Construction 2 01-03-2009 05:34 PM
Questions on Building apartment On top of existing detached garage nsxman2001 Building & Construction 4 12-16-2008 05:36 PM
building a pole barn on a existing slab??? scott13676 Building & Construction 3 02-25-2008 07:29 PM
Home building process wilddngy General DIY Discussions 19 04-06-2005 03:17 PM
