Joist To Beam Attachment For Deck. - Building & Construction - DIY Chatroom Home Improvement Forum
Old 08-09-2011, 05:16 PM   #1
Joist to beam attachment for deck.
The plans call for setting 2x8 joists on top of 6x6 beams and attaching with a A35 Simpson brackets. Do you need one bracket on each side of the joist or one side only? The span is short but with snow load the engineer called for this hefty structure. Thanks, Ken
drken is offline   Reply With Quote
Old 08-09-2011, 05:57 PM   #2
Civil Engineer
Rewards Points: 5,246
The Simpson catalog shows one A35 connector for a joist to beam connection. The "Prescriptive Residential Wood Deck Construction Guide", IRC 2006 edition, shows one connector per joist is required (Figure 6, Option 2). However, the real answer is that you need to install as many hangers as the plans call for. If the plans do not specify how many hangers per connection, you should call the designer.
OSB Stronger than Plywood? Weathermaker01 Flooring 15 12-22-2012 10:06 AM
How to repair main support beam Jerry48ece Building & Construction 0 01-08-2011 09:38 PM
Space between joist and beam on deck schveiguy Building & Construction 11 09-08-2009 10:15 AM
Crawl Space Beam and Joist Support Questions Fire4Effect Building & Construction 5 06-28-2009 02:07 PM
i beam in basement, notched joist component Building & Construction 1 03-18-2008 02:47 AM
