Joining Two 6x6 Porch Posts Together. - Building & Construction - DIY Chatroom Home Improvement Forum
Like Tree4Likes
  • 4 Post By rjniles
Old 12-06-2019, 11:37 AM   #1
derekeh's Avatar
Rewards Points: 14
Joining two 6x6 porch posts together.
My friend bought a mobile home that has a 30x10 back deck with roof. The posts went from the ground to the roof. They sawed the posts off at the ground. The porch is now on a trailer and just needs put in position. I need to dig post holes and put roughly 3' 6x6s in the ground and attach them to the existing posts. I'm wondering how you all would recommend me attaching then together. Like a straight cut and angle some screws, notch the ends and screw together, or use a metal bracket of sorts. Thanks.
Sent from my Pixel 3a using Tapatalk
derekeh is offline   Reply With Quote
Old 12-06-2019, 11:44 AM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 13,220
Re: Joining two 6x6 porch posts together.
How far were they cut and how much do you have to go to marry them up?
Old 12-06-2019, 11:51 AM   #3
retired framer
Rewards Points: 15,210
Flat straps with HD galvanized nails on two sides like side and back should do it
https://www.homedepot.com/p/Simpson-...416Z/202329571
Do not use flat bottom gables with scissor trusses.
https://www.fema.gov/media-library-d...6/chapter7.pdf
figure 7-14
Nealtw is offline   Reply With Quote
Old 12-06-2019, 12:41 PM   #4
derekeh's Avatar
Rewards Points: 14
Here is what I have. Just need to attach posts that are between 2 and 3 ft to them
Old 12-06-2019, 12:47 PM   #5
A "Handy Husband"
rjniles's Avatar
Rewards Points: 884
I would pour 10" Sonotubes up to the highth you need and attach wood to the concrete.
My electrical answers are based on 2017 NEC, you may have local amendments.
Old 12-06-2019, 12:48 PM   #6
retired framer
Or just cut them off flush with the bottom of the deck and install new
figure 7-14
Old 12-06-2019, 01:36 PM   #7
Rewards Points: 206
I like post #5, but post #3 might be O.K. Mostly you just need to hold them in place, some lateral force when the wind blows and drunks fall. If you want it to look pretty, cut a deep notch and screw with flat head galvanized (or better) screws.
udraft is offline   Reply With Quote
