Thread Tools | Display Modes |
#1 |
Rewards Points: 108
![]() jack post or wood post
Hello all, have a house that has an old power line wood post supporting a support beam in my basement. there's a large vertical gap in the post now. the beam is supported on both ends by a stone foundation wall. should I replace the post with a jack post, or would a 4x4 or 6x6 wood post suffice? thanks.
Sponsored Links | |||
Advertisement |
#2 |
Rewards Points: 18,118
![]() Re: jack post or wood post
Got a picture?
Just sounds like what's called checking, any 4 X 4, or 6 X 6 will do the same thing. It's caused by uneven drying and in most cases has no effect on strength. Nealtw likes this.
When posting in forums, letting us know your location will help others give better feedback/advice/solutions to your questions |
The Following User Says Thank You to joecaption For This Useful Post: |
woodypecker (12-11-2018)
Advertisement |
#3 |
Rewards Points: 108
will try and get a pic. thanks
Advertisement |
#4 |
DIY Your Own Air Bed
Rewards Points: 332
Probably not a 4x4
Nealtw likes this.
Engineered Beds DIY Air Bed For A Fraction Camping beds, Guest Beds, House Beds https://www.soveiluften.com |
#5 |
Rewards Points: 2,072
If your asking the question about strength I feel your concern. For piece of mind I would install a steal column with plates on top and bottom and forget about it.
No Warranty Means- If it breaks in half you get to keep both halves. |
#6 |
Residential Designer
The checking in and of itself is probably nothing to be concerned about, leave it alone and learn to stop worrying so much.
Andy. Bondo likes this.
#7 |
Rewards Points: 2,800
If you do replace the post then get someone in to determine whether there is a footing as opposed to just the concrete slab underneath, and more importantly to determine whether a new footing is needed.
Then your choice of wood or steel post.
Stick to your lawn watering schedule until it really starts to pour. After the storm you have only the same number of rest days you always had and then you need to start watering again. |
Thread Tools | |
Display Modes | |
Thread | Thread Starter | Forum | Replies | Last Post |
Will a Jack Post Lift? | smata67 | Building & Construction | 7 | 08-03-2012 03:12 PM |
Post base for wood porch | Quercus | Building & Construction | 2 | 07-22-2012 03:43 PM |
wood post support of second-storied kitchen overhang | mark_he | Building & Construction | 18 | 01-02-2012 08:33 PM |
Wood Fence with metal post | BDestroyer8418 | Building & Construction | 8 | 09-24-2011 10:49 PM |
