This Isn't Load Bearing, Is It? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 08-16-2016, 05:41 PM   #1
Rewards Points: 16
This isn't load bearing, is it?
Hi all, I am looking for a few opinions on whether people think this is a load bearing wall. From what I can tell it's not, and the other people I have consulted agree. Before I go ahead and start taking it down, I was hoping for some others to chime in.
As you can see from the pictures this part of the house has a cathedral ceiling. Based on what I know about cathedral ceilings the load bearing walls are usually the outer walls, and sometimes the middle carries load as well.
We have a wall and support beams down the middle at the peak of the roof. Which is continued into the basement with another beam. The wall that I am looking at removing runs perpendicular to the center beam, and parallel to the floor joists below. It seems to me like it's just a partition wall, but thought I would post some pictures while I have the drywall off.
Here is the wall in question.
Here is a close up of the top plate of the wall.
Here is the floor joist cavity below. No beam, but one floor joist to help carry the weight of the wall.
So based on this, what do you think? I appreciate your opinion.
colesy is offline   Reply With Quote
Old 08-16-2016, 07:47 PM   #2
Rewards Points: 16
Re: This isn't load bearing, is it?
One more picture with all the drywall down.
Old 08-16-2016, 09:04 PM   #3
Rewards Points: 17,940
Most likely not but you really need someone that knows what there doing to be onsite to look it over.
No way on any website can anyone do but guess, really want to rely on a guess on your home?
The Following 2 Users Say Thank You to joecaption For This Useful Post:
Msradell (08-17-2016), SHR Plumber (08-17-2016)
Old 08-29-2016, 06:14 AM   #4
Rewards Points: 16
Originally Posted by mkioiu View Post
Apparently not.
Apparently not, what? Wall has been removed and all is good, no load above it.
Identifying Load Bearing Posts Reader1 Remodeling 3 06-10-2016 08:47 AM
Window in a load bearing wall diychat09 Remodeling 4 03-08-2016 08:27 PM
Floor Joist Replacement for Load Bearing Wall - Balloon Construction EliseA Building & Construction 1 10-26-2015 08:20 AM
Load bearing post Removal Beaumeri Building & Construction 8 03-04-2015 05:54 PM
Load bearing or partition thoughts? Cutiger26 Building & Construction 0 04-20-2014 03:15 PM
