Ipe Decking - Building & Construction - Page 2 - DIY Chatroom Home Improvement Forum
Old 06-13-2009, 11:49 AM   #16
Originally Posted by DangerMouse View Post
hi geordon, i would highly recommend doing both sides, yes.
DM
Thanks for the quick reply.
Would it be okay to seal the bottom side as I go with Penofin Bronze then flip the board rightside up? Then after the entire deck is installed, do the surface all at once? I am thinking this way I wouldn't be sealing lumber I may not use or the cutoffs.
Geordon is offline   Reply With Quote
Old 06-13-2009, 12:18 PM   #17
the Musigician
DangerMouse's Avatar
cut piece to size, finish both sides and ends, then mount.
DM
Old 06-13-2009, 01:32 PM   #18
Actually, doing it board by board is going to take a lot of time and a lot of space. It takes a number of hours before it can be handled, that is the Penofin I am talking about. Just make sure to seal the ends with wax, then when you are done, finish off with Penofin. You usually apply heavy and then wipe off after 15 to 20 minutes. If you leave it on and don't wipe it will be sticky and take a few days to cure and won't look right. Don't wait too long because the board will grey after a few weeks. Of course you can always sand them down and they will look brand new but why go through the extra work. Finishing off the bottoms is really unnecessary IMO. Ipe will last forever, even untreated. Treatment is mostly to bring out the beauty of the wood unlike some other decking materials.
Josh Jaros Remodeling in The Woodlands, Texas www.jarosbros.com
jaros bros. is offline   Reply With Quote
Trex decking LL1 General DIY Discussions 56 09-30-2011 09:55 PM
installing plywood or backer board over decking gwags Building & Construction 6 04-02-2009 04:55 AM
Decking Michael Avram Building & Construction 2 05-26-2008 07:24 PM
Plastic decking? kcrossley2 Building & Construction 4 10-08-2007 10:59 AM
