Intermittent Popping Subfloor - Building & Construction - DIY Chatroom Home Improvement Forum
Old 02-07-2015, 09:55 PM   #1
Rewards Points: 373
Intermittent popping subfloor
Getting ready for new carpet install so pulled out 900sf of carpet and padding upstairs, fun!, not.
So in one room I had several issues,
1. A crown over one of the floor joists that extended halfway through the room
2. plywood subfloor was loud as it was not secure to the joists in many areas, nails lifted a bit, 35 yr old home. I could see a few nails lifting.
So I solved the crown with my belt sander, and the screwed the loose subfloor down to the joists with deck screws. I also pulled a lot of loose nails and used screws instead.
So now I am getting a random pooping noise when walking around the room? Not all the time? WTH??
Any suggestions? Need photos?
titan7 is offline   Reply With Quote
Old 02-07-2015, 11:57 PM   #2
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Do you mean like flatulence sounds?
Just add more screws where necessary.
XXX
Old 02-08-2015, 12:32 AM   #3
Rewards Points: 5,010
What do you mean by crown.?
What you are describing, sounds to me, the plywood is either under sized or the wrong type.? Maybe the same goes for the floor joist.?
ron45 is offline   Reply With Quote
Old 02-08-2015, 12:10 PM   #4
Rewards Points: 373
Crown is a high spot on the subfloor. One of the joists is high causing a high spot on the finished floor where two sheets of plywood come together. I sanding it down a bit to lessen the crown or bump. The sub floor also was not 100% secured to the joists as I could hear the subfloor hit the joists while walking around the room. I did not hear this popping sound until I started screwing the floor Down tight to the joists. That does not make sense,
Old 02-08-2015, 12:32 PM   #5
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Add more screws where necessary.
XXX
Old 02-08-2015, 01:27 PM   #6
Rewards Points: 373
Added more screws, still getting a creak sound in one area, see photo. The edge of the plywood was pretty beaten up from the nails being pounded in. And there was a large gap between the sheets. I have put a screw into the edge about every 3 inches. Should I cut out this section of plywood and replace it, I could then glue it down first. The way the framing is done at this spot there are joist supports all around this piece. I would only replace from this bad edge to the next joist 16 inches to the right. The area creaking has the box on it.
Old 02-08-2015, 03:08 PM   #7
Tileguy
JazMan's Avatar
Rewards Points: 780
Patches should be supported by at least 3 joists, two is not enough. You should be able to get away with it with certain types of flooring like carpeting as you are using though. For most cases, patchs should therefore be min. 32" wide and supported on all sides or covered by a second layer of underlayment.
Is the floor unfinished from below?
Jaz
MARBLE from ITALY & GREECE -PERLATO-PERLATINO-BOTTICINO-THASSOS-SIVEC-VOLAKAS-CALACATTA- NAXOS-Slabs-Tiles-Custom containers shipped to you - [email protected]
Old 02-08-2015, 03:32 PM   #8
Rewards Points: 373
The patch would be supported in all four sides. See the photo above with the box, hammer, and cat paw, visualize a rectangle within this area with is 36x16. That would be the size of the patch and there are joists under all four sides, if you expand the photo you can see the seams of the plywood sheets and the nails/ screws. Is it worth trying this or a waste of time?
I am really up against the wall with carpet coming on weds. I can push that back if needed.
Old 02-08-2015, 05:41 PM   #9
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Something isn't making any since here. How long are the screws you are using? I'm thinking the Phillips-head screws you are using are the cheapest screws on the shelf and not very good ones. You should be using a deck screw with plenty of length and high threads and a Torx-drive. Go get some real deck screws and pay around $8 per pound for them, then draw them down tight sinking the screw head slightly.
I'm thinking those screws are stripping themselves and your tool is skipping and hopping out of the head, you don't seem to be "setting" the screw heads.
XXX
Old 02-08-2015, 11:56 PM   #10
Tileguy
JazMan's Avatar
Rewards Points: 780
Titan,
You're ok with the 16" width since you're going with carpet, with the exception of the noise. I was suggesting that with other types of flooring the patch needs to be supported by min. 3 joists, in addition to the ends of course. When supported by only two joists you'll get curvature when a load is applied to the center causing both edges to peak. This is important, but not with carpeting.
Again, in the ceiling below unfinished or finished?
Jaz
Old 02-09-2015, 08:35 AM   #11
I had the same problem when I replace carpet with laminate . Re-nailed the subfloor and then a squeak started when walking over certain areas. I crawled under the house and found a nail rubbing on a hanger when walking over the area. Secured the nail and the squad stopped .
Sent from my iPad using Tapatalk
davidad1 is offline   Reply With Quote
Old 02-09-2015, 09:44 AM   #12
Ole Wood Worker
BigJim's Avatar
Rewards Points: 586
Anyone notice the plywood is running the wrong way in one of the pictures? That would cause more movement if the plywood runs with the joists instead of across. I may just be looking at it wrong.
New members: Please consider adding your location to your profile.
Lawyers believe a man is innocent until proven broke.
If you do what you've always done, you'll get what you've always got.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is offline   Reply With Quote
Replace Rotted Subfloor Kory Beam Building & Construction 37 12-16-2014 06:17 PM
Subfloor and P-trap for basement bathroom svaic00 Plumbing 9 10-11-2012 01:51 PM
How should I reinforce this subfloor? NewHomeDIYGuy Tiling, ceramics, marble 35 12-05-2011 11:01 AM
Need guidance on subfloor problems in new home. wb1026 Flooring 9 10-06-2009 07:29 AM
Subfloor / underlayment question... scheenstra Flooring 7 02-21-2008 08:39 AM
