Interior Cinderblock Wall Covering What To Use??? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 09-02-2010, 01:59 AM   #1
Interior Cinderblock Wall Covering what to use???
What can be use to cover the interior room that's a painted cinder block wall?? Could bead board be used? I just want a fresh look other than looking at all those blocks! Nothing but cinder block in the entire house with skim cover over most rooms, but the last addition wasn't skim with anything! Please see my album of my work in progress!
Thanks!
gapeahen is offline   Reply With Quote
Old 09-02-2010, 07:54 AM   #2
Ole Wood Worker
BigJim's Avatar
Rewards Points: 799
Make sure your walls are sealed good as most anything will go bad with moisture. In that climate if it were my home I would go with a T&G 1X6 or 1X8. You may get away with using good paneling but stay away from the particle board, MDF or tempered masionite as you will for sure have problems with them. I would strip the walls with 1Xs using deck screws. Drill a hole the same size as the screw, cut some strands of #12 romax, place a single strand of the wire with the insulation in the hole and bend the wire over so it won't slide into the hole and screw the wood to the wall, it will hold for a fact I have hung cabinets like that.
New members: Please consider adding your location to your profile.
Lawyers believe a man is innocent until proven broke.
If you do what you've always done, you'll get what you've always got.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is offline   Reply With Quote
The Following User Says Thank You to BigJim For This Useful Post:
gapeahen (09-09-2010)
Old 09-09-2010, 12:09 AM   #3
Cypress
Jim,
Would cypress 1x's work as you have suggested? Would it be nessacery to install 1/2 inch installation on those cold walls, or would that be just extra expense.
Old 09-09-2010, 08:08 AM   #4
Ole Wood Worker
BigJim's Avatar
Rewards Points: 799
Cypress would sure work great and it will last. If it were mine I would use as much insulation as will fit on the exterior walls, the more you can insulate the inside temperature from the outside temperature the better IMHO.
Jim
Old 09-11-2010, 02:41 AM   #5
Cypress Wall
Thanks Jim, I think I'll be using the cypress, looks like it's going to be my best choice. I do have a good bit of 1x4x12 cypress on hand.
The Following User Says Thank You to gapeahen For This Useful Post:
BigJim (09-11-2010)
Tags
cement block walls , cinder block wall
Removing a 4 foot opening in a load bearing wall (for fish tank) ~callie~ Building & Construction 1 07-15-2009 05:10 PM
Breaking up a long/continuous wall tigereye Interior Decorating 4 03-08-2009 03:43 PM
Loads on a partition wall acyate Building & Construction 8 02-28-2009 11:02 PM
Atlantic-need your opinion on markd's comments about my vapor barrier? yummy mummy Building & Construction 11 03-07-2007 09:47 AM
Load Bearing Wall? Traybae Building & Construction 1 11-05-2006 01:01 PM
