Insulation Worht It Or Not? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 09-23-2009, 05:09 AM   #1
insulation worht it or not?
Good morning,
My question is, Do I need to insulate the ceiling of the basement. I am also thinking to make it soundproof as I am making home-theater in basement. What kind of sound proofing material should I use? I mean Should I go with insulation which gives me sound proofening or should I leave the insulation and just add material (like foam)to make it sound proof. Or If there is any better choice exists?
Randy
raulakh is offline   Reply With Quote
Old 09-23-2009, 06:01 AM   #2
True soundproofing involves isloating framing members from each other and is expensive. Likewise, true sound insulation that can be laid between joists is also expensive. Standard insulation does give some sound insulation, but not a lot.
Old 09-23-2009, 10:06 AM   #3
Rewards Points: 116
Sound proofing information:
http://www.soundproofing101.com/
http://www.glacierbay.com/insulation_ultradb.asp
http://www.acousticsfirst.com/vinyl.htm
http://www.soundprooffoam.com/
Edit: The two sites GBR in WA mentions in the next post have been removed. Thanks GBR.
Last edited by gma2rjc; 09-23-2009 at 05:04 PM. Reason: remove two links that don't work
gma2rjc is offline   Reply With Quote
Old 09-23-2009, 01:16 PM   #4
Registered User
Rewards Points: 526
Since two of those sites did not work, here is another: http://www.certainteed.com/resources...%20Control.pdf
Be safe, Gary
Old 09-23-2009, 01:37 PM   #5
Drywall contractor
Rewards Points: 1,114
You're looking a a lot of money to sound "proof" for a home theater. There are ways to help "lessen" the sound, but still not exactly inexpensive. You might also check some of the drywall mfgr's. sites for information. United States Gypsum, for example has an online handbook. Sound control is covered in one section....
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
Old 09-24-2009, 12:09 AM   #6
Exclamation
I am also wondering if I really need to insulate the ceiling or not ?
Old 09-24-2009, 12:35 PM   #7
Registered User
Rewards Points: 526
Only if you don't want to hear noise from below.
Be safe, Gary
Cape Cod Style House Attic/Crawl Space Insulation Help Danielg Insulation 24 05-21-2012 08:20 AM
How To Install Rigid Foam Insulation on Concrete earthad1 Building & Construction 9 10-26-2010 09:49 AM
Old home insulation woes nowwhatnapster Building & Construction 15 11-02-2008 11:59 PM
attic insulation question dderolph Building & Construction 10 11-03-2007 05:21 PM
Installing new insulation in my basement and removing the old moldy insulation. Fixitgeorge Remodeling 3 10-17-2006 08:33 PM
