Insulation - Building & Construction - DIY Chatroom Home Improvement Forum
Old 01-01-2011, 12:02 PM   #1
insulation
I have a small cottage which does not have a foundation, it sits on concrete posts. I now want to insulate it. Is spray foam a good way of doing it?
sonny1954 is offline   Reply With Quote
Old 01-01-2011, 01:04 PM   #2
Rewards Points: 6,652
I would Spray foam in this case. It would keep the creepy critters from getting into the house, plus would seal the bottom better than batts or extruded foam.
Cape Cod Style House Attic/Crawl Space Insulation Help Danielg Insulation 24 05-21-2012 09:20 AM
Fiberglass Insulation: How Do I Cover the Attic? chueh Building & Construction 3 11-08-2010 03:33 PM
How To Install Rigid Foam Insulation on Concrete earthad1 Building & Construction 9 10-26-2010 10:49 AM
How hard to install insulation yourself? techprincesse Building & Construction 26 10-17-2009 10:57 AM
Installing new insulation in my basement and removing the old moldy insulation. Fixitgeorge Remodeling 3 10-17-2006 09:33 PM
