Insulating - Building & Construction - DIY Chatroom Home Improvement Forum
Old 12-03-2009, 06:38 PM   #1
insulating
My home is about 20 years old. originally had a carport and the person that lived here prior to the one before me had closed in the carport to create a living room. He also installed a woodburning stove. I don't think that he insulated the exterior of the room, It is just siding and r-max. what do you guys think might be the best and cheaper way to insulate these exterior walls.
Toolmaster is offline   Reply With Quote
Old 12-03-2009, 08:11 PM   #2
Rewards Points: 360
Are the walls drywall? Is there insulation above the room?
7echo is offline   Reply With Quote
Old 12-06-2009, 03:01 PM   #3
yes walls have drywall, yes there is insulation in the attic, very old, and have not checked the depth, looked like 6-8 inches
Old 12-06-2009, 03:07 PM   #4
if you have switch or recept on outside wall pull cover plate sometimes you can see between box and drywll for inso being present
Insulating basement ceiling - your recommendations? jtmann HVAC 8 11-24-2009 04:44 PM
Insulating brick above & close to grade Peter Shepherd Building & Construction 1 09-16-2009 06:41 AM
Insulating crawl space jenoble99 Building & Construction 10 06-18-2009 12:09 PM
worth insulating pipes? wombosi HVAC 4 02-15-2009 06:32 PM
Insulating A/C ducting ? Scott_K HVAC 1 10-04-2007 06:21 PM
