To Insulate Or Not - Building & Construction - Page 3 - DIY Chatroom Home Improvement Forum
Old 01-08-2010, 08:09 AM   #31
Remodeling Contractor
In CO spray foam would be very useful and by far the best way to go. It provides a higher per inch R-Value and a much tighter air seal then batt insulation. Open cell will is air permeable so is a great solution for insulating roof rafters in your area. No cold air space from roof vents will be needed with this method. Closed-cell will be better for new construction wall cavities since it yields a higher per inch R-Value but at a greater costs. As to costs, you need to refer to local vendors.
Insulate basement header with imbedded joists??? lackofunds General DIY Discussions 21 04-17-2011 03:41 PM
Is it advisible to insulate under a ceiling Karsten Building & Construction 2 12-13-2009 05:23 PM
How to insulate attic crawl space RISurfer Building & Construction 7 10-01-2009 11:57 AM
Insulate or Don't Insulate? helpless handyman Building & Construction 10 03-31-2008 06:07 PM
