Installing Windows - Building & Construction - DIY Chatroom Home Improvement Forum
Old 08-17-2009, 05:36 PM   #1
Installing windows
I need to replace some windows in a building with vertical half logs. I purchased vinyl windows with nailing flanges. The top and bottom flange will rest against the radii of the logs but the vertical flanges will probably not touch the logs since they are not wide enough to reach the thickest part of the log.
rgs02dms25 is offline   Reply With Quote
Old 08-17-2009, 07:52 PM   #2
SNC
sonds like you need to build a frame, like a box with no lid or bottom and set this in the opening then set your window in this.
SNC is offline   Reply With Quote
Old 08-18-2009, 07:28 AM   #3
Installing Windows
That was the approach I was considering. Since I purchased windows based on the R.O. my approach was to make a frame around the opening, install the window and trim it out. I originally planned on using 1" lumber but have been contemplating using 1/2" (probably will have to rip from plywood) to help minimize how thick the projecting surface will be from the face of the logs.
Windows XP Mode in Windows 7! poppameth PC Repairs & Upgrades 5 04-28-2009 12:18 PM
Novice question: Installing windows in wood sided home...(pic) Dr. Jim Building & Construction 5 07-06-2007 06:33 PM
Installing Windows after Drywall??? jeepwillies Building & Construction 9 11-22-2006 10:30 AM
How do I install new windows? RickT Carpentry 17 10-12-2006 06:06 PM
