Installing Stainless Steel Cabinets Into Outdoor Kitchen Setup - Building & Construction - DIY Chatroom Home Improvement Forum
Old 09-02-2018, 10:10 AM   #1
Rewards Points: 2
Installing stainless steel cabinets into outdoor kitchen setup
Hello everyone. Im building an outdoor kitchen, with some Bull cabinets/access doors. Im at the stage where Im going to install the ledger stone on the face of the structure Ive built, but Im confused on whether I install the stainless steel components first, and then install the ledger stone over top of the stainless steel trim, or install the stone first, then slide the cabinets in so the trim sits on top of the stone. If I do the latter, it looks like I wont be able to secure the stainless steel components, since the stone behind the trim will cause the pre-drilled mounting holes to miss my studs.
Any advice?
Thx.
Cdooer is offline   Reply With Quote
Old 09-02-2018, 11:38 AM   #2
Rewards Points: 22
Re: Installing stainless steel cabinets into outdoor kitchen setup
The manufacturers install sheet states on base units, to add 1.5 inch of opening around them when using stone. Just my take anyway on the read.....
https://www.bullbbq.com/sites/defaul...eet-150218.pdf
Gregsoldtruck79 is offline   Reply With Quote
Installing Closet Swinging Doors (Remove drywall + steel corners) ? westbank Carpentry 3 08-21-2014 08:49 PM
Loose stainless steel deck screws drtbk4ever Building & Construction 17 06-19-2012 10:26 AM
Using Simple Green stone cleaner & stainless steel appliances? mystiky Interior Decorating 1 02-22-2012 05:13 PM
How to clean stainless steel grill?? JohnnyD44 Appliances 2 07-21-2011 09:32 AM
Installing kitchen wall cabinets higher than spec recommendation? alexz General DIY Discussions 14 07-21-2008 12:32 AM
