Installing A Spiral Staircase - Building & Construction - Page 2 - DIY Chatroom Home Improvement Forum
Old 12-01-2013, 12:17 AM   #16
Ole Wood Worker
BigJim's Avatar
Rewards Points: 270
Originally Posted by Daugela View Post
How are you calculating the tread width?
3' 6" outside to outside, minus 6" for the post 36 " divided by 2= 18"
New members: Please consider adding your location to your profile.
Lawyers believe a man is innocent until proven broke.
If you do what you've always done, you'll get what you've always got.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is offline   Reply With Quote
Old 12-01-2013, 12:21 AM   #17
Ole Wood Worker
BigJim's Avatar
Rewards Points: 270
3' 6" outside to outside minus 6 inches for the center post, 36 divided by 2= 18"
Jim
Old 12-01-2013, 12:28 AM   #18
JOATMON
ddawg16's Avatar
Rewards Points: 10,026
Hey Dawg
What staircase diameter is that? I'm a bit confused on staircase diameters. I'm putting one in the garage as well and have the option for the 3'6" stair case diameter. I'm confused if that means the measurement is taken from the handrail to the center of the pole? Or the total width. Surely it can't be the total width.
thanks
The stair diameter is going to be 2 x the width of the tread + the dia of the center pole.
So....if you have a tread that is 24" wide....x 2 = 48 + 6" for the center pole.
I would NOT go anything less than 24". Mine is fine going up and down...but when you start carrying boxes....well...it's an issue sometimes.
The Following 2 Users Say Thank You to ddawg16 For This Useful Post:
BigJim (12-01-2013), Daugela (12-01-2013)
Old 12-01-2013, 12:15 PM   #19
Rewards Points: 1,238
It's actually not for a garage. But rather an emergency escape from a very large basement window well. The well is about 6 feet by 13 feet. The well goes all the way down to my basement floor and has a window AND door in the exit. Once you walk into the large window well, there is a mounted ladder on the wall. I would like to put in a small usable spiral case. Doesn't need to be big. Just a way of going up and down without using the ladder so much!
thanks
Daugela is offline   Reply With Quote
Old 12-01-2013, 12:17 PM   #20
I can't find anything in code prevented me from switching my emergency escape ladder to a spiral case.
Installing new doors, floors, and trim. toobhed Windows and Doors 5 03-16-2012 03:21 PM
Framing for drywall under Spiral staircase clemon03 Drywall & Plaster 6 07-17-2009 04:49 PM
Spiral staircase possible with 20" x 21" opening? t_bunson Building & Construction 12 09-09-2008 07:18 PM
Installing new wall receptacle... jaysen Electrical 18 06-10-2008 09:26 PM
Spiral staircase questions NateHanson Building & Construction 3 01-20-2008 09:49 PM
