Installing Motion Light - Building & Construction - DIY Chatroom Home Improvement Forum
Old 05-27-2014, 01:16 PM   #1
Rewards Points: 463
I am going to attempt to install a motion light where there is not one currently. I have the motion light, the junction box for the light and the junction box where I will tap into the electric source.
I am kinda unsure how to get it mounted onto the wall. Where I want to mount it is right below the attic vent in this picture but you see there is a 2x4 from the truss in the way. I do not want to mount it off center, it would bug the crap out of me! Any ideas on what I could do?
This is where I want to get my electric source, it is from the spare bedroom. It powers one electric outlet via a light switch. I know I will need to make sure to get the electric on the constant powered side and not the switched side.
cincinnati guy is offline   Reply With Quote
Old 05-27-2014, 03:46 PM   #2
Rewards Points: 463
After some thinking, I will run a new line from the electric panel to the light. I have plenty of open spots for a new breaker.
Still unsure what to do about the 2x4 for the truss.
Does there really need to be a junction box? Can I just drill a hole through the 2x4 for the wire and mount the light directly to that 2x4?
Old 05-27-2014, 04:12 PM   #3
Rewards Points: 342
No. That is a code violation.
JKeefe is offline   Reply With Quote
Old 05-27-2014, 08:37 PM   #4
Rewards Points: 254
How about a shallow box in the outside the light will attach to,drill through stud and attach to inside junction box with PVC pipe?
cjm94 is offline   Reply With Quote
Old 05-27-2014, 09:32 PM   #5
Rewards Points: 463
Here is what I ended up doing. I mounted it off center. I didn't think about mounting a shallow junction box outside.
I cut a hole from the inside then cut out the siding. Mounted the junction box into the hole. It didn't come out perfect. I used plenty of silicone I think to make sure its good and sealed.
Installing motion sensor security light on Garage redbeast Electrical 14 10-18-2013 01:54 PM
Dual wiring for motion sensor security light ent Electrical 2 09-14-2011 03:00 PM
Permanently Bypass Motion Sensor Light pwlear Electrical 1 05-22-2011 04:27 PM
general wiring question (installing exterior light) utilitylocator Electrical 7 01-24-2010 12:52 PM
Motion Light tripping GFCI? Jonobp Electrical 5 09-07-2009 08:52 PM
