Installing Melamine Finished Tilepanel - Building & Construction - DIY Chatroom Home Improvement Forum
Old 12-28-2009, 03:25 PM   #1
I bought some Melamine Finished Tilepanel from Lowes that is smooth & white on one side like what you would see in a bathroom or laundry room. Instructions call for a Mastic of Asphalt Emulsion type adhesive. The instructions go on to say it needs to be applied with a trowel 3/16” to ” notches.
Of course, none of the fine people at Lowes have a clue what I should buy.
You guys help me out? I looked at the Liquid Nails FRP 300 Adhesive, but I am not sure it will work. I am putting this stuff up on a wood wall. I have access to Liquid Nails FRP 310 if that is better.
Nitrors4 is offline   Reply With Quote
Old 12-29-2009, 01:12 PM   #2
No one have any experience with installing these sheets?
Old 12-29-2009, 02:08 PM   #3
Rewards Points: 2,698
Try this site:
http://www.decpanels.com/install-smooth.html
This is the site of the DPI tileboard mft that Lowes.com has on its site. They recommend: "Use a high quality, solvent-based trowel grade Tileboard or construction adhesive. Do not use water based or FRP adhesive, as they will not work.
In high humidity areas: Use a flat trowel, and apply a thin layer (also called a skin coat) to the wall area you will be covering with the panels. Go directly to next step to apply adhesive to the wall panels."
Make sure this is the right tileboard since instructions may vary depending on type. Also, they've some info on conditioning the sheets to the home's climate prior to installing; may be useful in preventing buckling in the future.
bob22 is online now   Reply With Quote
Old 12-29-2009, 02:20 PM   #4
I actually looked at that site, but these panels are not from dcpanels. They come from Aucatex which does not appear to have a US website.
Old 12-29-2009, 02:30 PM   #5
Years ago, tileboard adhesive in caulking tubes was always available in the same store where you buy the tileboard. Haven't looked for it since I haven't put in any tileboard lately.
LIquid Nails site:
http://www.liquidnails.com/products/...tId=28#details
says this stuff is for tileboard (along with a lot of other stuff).
LIQUID NAILS ADHESIVE
15885 West Sprague Road.
Strongsville, OH 44136
Phone: (800) 634-0015 (try calling them and asking what product of their's is the same as what tileboard instructions recommend)
E-mail: [email protected]
Might ask another person at the blue store or try HD to see what they recommend.
OK to do a short, unsupported, vertical run of romex in finished wall? TomServo Electrical 2 10-04-2009 07:43 AM
Finished attic humidity? kcrossley2 HVAC 2 08-11-2009 05:06 AM
Installing stand-up shower in finished basement without existing drain notenoughtime Plumbing 3 05-16-2009 11:59 AM
Installing plinth blocks? Badfish740 Carpentry 6 02-09-2009 10:45 AM
Installing Registers in finished basement boinger HVAC 2 02-07-2007 03:44 PM
