Installing Lvl Ridge Beam - Building & Construction - DIY Chatroom Home Improvement Forum
Old 06-28-2010, 08:38 AM   #1
installing lvl ridge beam
I am putting on a second storey that is 15 x 25.. Approximately what size LVL ridge beam would I need to span 15' .The floor joists are running parrallel to the ridge.Also what size posts would be required to support this? Thanks
john morley is offline   Reply With Quote
Old 06-28-2010, 08:42 AM   #2
kwikfishron's Avatar
Rewards Points: 832
What does your approved plans call for?
kwikfishron is online now   Reply With Quote
Old 06-28-2010, 10:51 AM   #3
Rewards Points: 3,130
What kwik said. Installing such a beam is certainly a DIY job; doing the engineering to figure out what size is not.
Old 06-28-2010, 11:03 AM   #4
Ole Wood Worker
BigJim's Avatar
Rewards Points: 1,363
Are you going to have ceiling joists or is this a vaulted ceiling?
BigJim is offline   Reply With Quote
New ridge beam support needed for cathedral ceiling? zachalyse Building & Construction 12 06-06-2010 07:06 PM
gap between ridge beam and ridge board mdudu Building & Construction 6 05-07-2010 08:46 PM
Condensation on my ridge beam... D-Hoggs Roofing/Siding 4 03-22-2010 03:48 PM
Rafter to ridge beam height JESSBRA2 Building & Construction 1 10-20-2008 03:34 PM
ridge beam rakuz66 Building & Construction 8 07-29-2008 12:01 AM
