Installing Felt Under LP Smartside Paneling - Building & Construction - DIY Chatroom Home Improvement Forum
Old 07-24-2011, 07:12 PM   #1
cortell's Avatar
Rewards Points: 504
Installing felt under LP smartside paneling
I'm planning to replace LP SmartSide paneling on a rental property with the same. I figured I'd install 15lb felt underneath it. Since the LP paneling is sheathing and siding combined into one, I'll be laying the felt directly on framing members (studs, headers, etc).
1. I've never installed felt paper on framing. What sort of fasteners and schedule should I use?
2. I'll be using self-adhesive flashing around openings. I'm not removing/reinstalling windows and doors. Should the flashing rest over the felt edge (partially, of course), or be under it?
BTW, there's no point in cautioning me against using LP SmartSide. I'm only doing the back of the home (where the product has failed). I need the replaced area to match the rest of the house (3/4 of the home is LP). No time or budget for a complete re-siding to something else.
cortell is offline   Reply With Quote
Old 07-24-2011, 10:23 PM   #2
AGWhitehouse's Avatar
Sounds like a horrible idea to me to put felt directly on studs, but you've made it clear we can't talk you out of it, so let us know when it fails again...
Life's too short...so enjoy it!
AGWhitehouse is offline   Reply With Quote
Using Felt with Cedar Shakes freddmc Roofing/Siding 32 10-08-2011 12:26 PM
Adhesive window flashing and 30# felt Numb Building & Construction 4 05-24-2011 12:04 AM
Couple Questions on installing real wood 4x8 beadboard paneling (Georgia Pacific) RickDel Carpentry 4 07-07-2010 03:46 PM
Installing Beadboard paneling Sannikay55 Remodeling 1 09-18-2009 05:38 PM
uneven wood paneling joefromcal Carpentry 6 04-30-2009 10:50 PM
