Installing 9" Staggered Rough-Split Shakes - Building & Construction - DIY Chatroom Home Improvement Forum
Old 07-19-2010, 07:54 PM   #1
Iam about to start siding my Gable on my new porch, and iam installing 9" Staggered Rough-Split Shakes, But the qustion i have is how do you figure the angle as your running up? I hope you can understand what iam trying to say?
splinter2 is offline   Reply With Quote
Old 07-19-2010, 08:22 PM   #2
kwikfishron's Avatar
Rewards Points: 846
Any gable I’ve ever cut I don't care what the actuall degree of the angle is because it realy doesn‘t matter.
You scribe it.
You run your level coarse until it hits the angle, then hold a board or something as a straight edge against the angle of the roof and scribe a line. Cut that on a scrap and you have your angle pattern.
kwikfishron is offline   Reply With Quote
Old 07-19-2010, 08:45 PM   #3
installing
kwikfishron,
Thanks for the tip, I kind understand wish there was a picture... I dont want to mess these up, because they are expensive...
Installing a bigger window. Creating new rough opening DIYChic Building & Construction 2 10-17-2009 06:14 PM
Installing bifold doors in a non-standard rough opening michelob Carpentry 7 05-15-2009 12:35 PM
installing split system>410 Jacques HVAC 7 09-06-2008 07:45 AM
installing a split system Jacques HVAC 6 07-10-2008 08:50 AM
Installing a mini split ductless system agenkin HVAC 1 06-14-2008 09:33 PM
