Install Exhaust Fan With No Attic Access - Building & Construction - DIY Chatroom Home Improvement Forum
Like Tree2Likes
  • 1 Post By Windows on Wash
  • 1 Post By hpdad
Old 05-29-2017, 03:12 PM   #1
Rewards Points: 42
Install exhaust fan with no attic access
The bathroom is on the first floor. It has the ceiling light and I want to replace it with new exhaust fan. The wires are there so that no need for wiring.
No attic access, only about 1.5 ft high of the space between the ceiling and the bottom of second floor. The fan where it will be install is about 6 ft from the wall.
With no attic access, how to make a frame for the fan?
Or any idea how to install the fan?
hpdad is offline   Reply With Quote
Old 05-29-2017, 05:23 PM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 8,332
Re: Install exhaust fan with no attic access
Have you figured out how to vent to the exterior?
Not sure what you mean by "frame"? The exhaust fans come with expandable brackets that are made to hang the fan between the framing.
lenaitch likes this.
Old 05-29-2017, 05:36 PM   #3
Oso954's Avatar
Rewards Points: 850
Depends what you mean exhaust fan. If it is fan only or fan with light and you don't mind them working simultaneously, you are right.
But bathroom exhaust fans also offer night lights and heaters. You could need additional wiring and switches to switch all 4 options independently.
Oso954 is offline   Reply With Quote
Old 05-29-2017, 06:06 PM   #4
Rewards Points: 8,048
if a 2' x 3' section of drywall were removed then the installation would be simple. The project would then turn to getting that drywall back and looking nice and that is very reasonable to do.
Bud
Bud9051 is offline   Reply With Quote
Old 05-30-2017, 04:49 PM   #5
Rewards Points: 42
The exterior wall is about 5-6 ft away. I will run this http://www.homedepot.com/p/Broan-Wal...VK2A/100626154
I saw video install the fan, people nail the bracket to floor or to 2x4 . There is no joist so I can nail the bracket of the fan on.
The bathroom has lights on the top on mirrow and we are using those lights. The light on the ceiling we don't need so I wanted to install the fan. It has three wires system (hot, neutral, and ground). The fan is just a fan, no other features.
Bud
I don't want to remove dry wall space more than the fan because I can re-batch the dry wall but not the texture.
This is the light
bob22 likes this.
Best material for attic access panel ADKMatt Insulation 3 10-25-2011 08:14 AM
Angle for trim around attic access hole? Cubey Carpentry 6 10-21-2011 04:30 PM
Ventilating attic with two roofs senorbungle Building & Construction 2 01-09-2011 05:17 PM
Install HRV duct in attic? dalyman0 HVAC 1 10-21-2008 08:47 PM
Moving Attic Access -- Same Rafter or Different ?? wrldruler Carpentry 1 10-19-2008 07:03 PM
