Install 4x4 Post With Vinyl Sleeve To Exisiting Slab And Top Header - Building & Construction - DIY Chatroom Home Improvement Forum
Old 08-20-2010, 03:41 PM   #1
install 4x4 post with vinyl sleeve to exisiting slab and top header
I have an existing porch that I want to remove the 4x4 post, sleeve them with a vinyl sleeve and remount.Can I use a standard post mount secured to the concrete?I do not see how you can screw the sides of the post mount to the 4x4 post when using a vinyl sleeve?
How do I mount the top to the header with a vinyl sleeve on the post?
Rusty Johnson is offline   Reply With Quote
Old 08-20-2010, 05:50 PM   #2
install 4x4 post with vinyl sleeve to exisiting slab and top header-image1.jpg
RDGreen is offline   Reply With Quote
