Increasing The Height Of The Foundation In A Room. - Building & Construction - DIY Chatroom Home Improvement Forum
Old 11-23-2010, 08:44 AM   #1
Increasing the Height of the foundation in a room.
I am thinking about building up the slab in my dining room to level it with the kitchen in order to increase my kitchen space. The kitchen is 6" higher. The dining room is 12' x 16'. I am a little concerned about adding the additional weight of concrete to the current concrete slab. Is there a composite material similar to Schluter Systems that can be used to achieve this or should I not be concerned about adding the additional concrete? Thanks for any help. Scott
shimanole is offline   Reply With Quote
Old 11-23-2010, 09:17 AM   #2
Chicago, IL
Michael Thomas's Avatar
Why not just build a conventional floor over the existing slab, with the joists sitting the slab, shimmed as necessary?
Home Inspections, Infrared (Thermal Imaging) Leak Identification and Inspection Services, Roof, Attic, Building, Basement and Foundation Moisture Intrusion and Water Leak Inspections, Troubled Building Consultations - Serving Chicago and Suburbs http://paragoninspects.com/
Michael Thomas is offline   Reply With Quote
The Following User Says Thank You to Michael Thomas For This Useful Post:
shimanole (11-23-2010)
Old 11-23-2010, 09:34 AM   #3
I guess my only concern is that I live in Florida with very high humidity and moisture but I know very little about construction and am just trying to get some ideas. Your suggestion is probably the easiest and most economical. Thank you
Old 11-24-2010, 11:29 PM   #4
Certainly the easiest thing to do is, 1/2" subfloor on 2x6 sleepers, but I have no idea if florida's climate would create any concerns. I'd call up the local bldg dpmt and tell them what you want to do, then ask them if there is anything to be concerned about. Maybe moisture buildup would require preserved wood. Maybe ventilation is required, or an access to the space. You could also take your ideas to a local home building store to get some opinions. Let us know what comes of it.
househugger is offline   Reply With Quote
Old 11-25-2010, 12:20 AM   #5
jlhaslip's Avatar
Rewards Points: 708
consider using pressure treated where you contact the existing slab
Short of cutting off a body part, the worst that can happen in woodworking is manufacturing really nice looking kindling. --- Quoted from lenaitch
jlhaslip is offline   Reply With Quote
Old 11-25-2010, 06:26 AM   #6
KCB
Thats alot of concrete , i doubt your existing footer could handle the extra wieght,id check with an engineer 1st .
You could use select treated 2x6 plus your subfloor sheathing in order to get your 6" but is that to a finsihed floor in your kitchen?Youll need to allow for a finished floor.Theres a couple of different options you could use.If the concrete option wont work id start with a lazer level and mark your finished grade along the perimeter walls less your sheathing and finish floor, to see how level you are in the room you wish to raise compaired to the kitchen floor.This will give you an idea of the lumber needed to do the job be it 2x6 ,2x4 etc...
As for moisture a good vapor barrier will be needed.
KCB is offline   Reply With Quote
Old 11-26-2010, 05:31 AM   #7
Rewards Points: 3,102
did this once - p/t's sleepers & 3/4" t&g ply over the top,,, prefer licens'd pro's but i'd ask the bldg dept 'fore ever considering any of the guys wearing vests or aprons
reclaiming bathroom cabinetry for laundry room - how to adjust to counter height? 7roses Carpentry 11 06-28-2009 07:07 PM
How to add footing and foundation to existing foundation? ptcamaro Building & Construction 6 06-22-2009 10:22 AM
Adjusting height on old dining room table hex27 Carpentry 3 06-14-2009 09:53 PM
Vents from boiler room RammsteinNicCage HVAC 3 03-11-2009 07:28 PM
A room in a room? artosie General DIY Discussions 2 03-10-2009 12:43 PM
