Ideas For Sliding Door Hanging Over Bare Earth - Building & Construction - DIY Chatroom Home Improvement Forum
Like Tree3Likes
  • 1 Post By joecaption
  • 1 Post By Nealtw
  • 1 Post By Exnihilate
Old 05-30-2019, 08:09 PM   #1
Ideas for sliding door hanging over bare earth
I am building sliding doors for a hoop house.
The doors hang from tracks that I purchased from the local Grainger.
The floor is bare earth and I drive my tiller over that area so I hesitate to install a threshold but I need something to stabilize the doors at the bottom.
The winds here go beyond 60mph so I am considering using a makeshift katie bar type solution to keep them secure until I figure something out.
Anyone have some ideas that can help me out?
Thank you for your time and help!
Exnihilate is offline   Reply With Quote
Old 05-30-2019, 08:15 PM   #2
retired framer
Rewards Points: 4,406
Re: Ideas for sliding door hanging over bare earth
Use roller guides.
https://www.ebay.com/itm/Adjustable-...MAAOSwKNhaqeMu
Do not use flat bottom gables with scissor trusses.
The Following User Says Thank You to Nealtw For This Useful Post:
Exnihilate (05-30-2019)
Old 05-30-2019, 09:23 PM   #3
Rewards Points: 18,228
Please post a picture of what your doing.
What's a "hoop house"?
What's a "katie bar"?
firehawkmph likes this.
Old 05-30-2019, 11:06 PM   #4
Thanks I think I will use those guides on the sides.
Maybe I could put in a concrete pole base where the doors meet.
Sorry I am so unprepared. I do not have any photos with me at the moment besides this one and the next time I will be back will be in half a week.
Ideas for sliding door hanging over bare earth-op.jpg This is an older photo before I started this project.
I added some rectangles to represent the tracks (on top in red) and the doors (orange)
A hoop house is like a greenhouse.
A katy bar in my case is a long 2x4 that I can put across the doors that will keep it from being pushed open.
Old 05-30-2019, 11:14 PM   #5
retired framer
Better is to have a little concrete there and a drop pin off one door and then the two doors are set up with a pin and hole system or a spline and grove so they fit together so it can be locked and will not blow in the wind. So one door is usually locked in place.
ChuckF. likes this.
Old 05-30-2019, 11:29 PM   #6
Wow that sounds perfect to me. Thanks much!
Nealtw likes this.
Old 05-31-2019, 05:51 AM   #7
retired painter
Rewards Points: 1,378
That's what I did on my barn [my son's lawnmower shed also] I dug down and inserted a short section of galvanized pipe [concreted in place] that corresponded with the slide bolt at the bottom of the door. Makes the doors very secure.
mark sr is online now   Reply With Quote
Old 05-31-2019, 06:43 AM   #8
Naildriver
chandler48's Avatar
Rewards Points: 740
I have double barn doors on my shop and use these on each side to hold the doors tight to the building. https://www.tractorsupply.com/tsc/pr...c?cm_vc=-10005
You could use one of these to join the two panels at the middle, as well as incorporating the rollers mentioned earlier. https://www.tractorsupply.com/tsc/pr...d?cm_vc=-10005
You didn't mention if there is a "man" door, or if this is the only door available. If this is the only door, then nevermind. You won't be able to get out once you lock it up.
Larry......
Half of Communications is Listening, and You can't Listen with your Mouth.
chandler48 is online now   Reply With Quote
Old 05-31-2019, 09:00 AM   #9
I have gas!
Clutchcargo's Avatar
Rewards Points: 1,916
You could use a hanging sliding barn door. it would be slightly above the ground.
I tear things down and build them up.
Clutchcargo is offline   Reply With Quote
Old 05-31-2019, 11:46 AM   #10
I do have another door. I will consider using these.
Old 05-31-2019, 11:47 AM   #11
I do. And it is.
Old 05-31-2019, 02:27 PM   #12
retired framer
We did one where we put a length of 6 inch channel iron under the door in the dirt and that worked.
