Idea's Required - How Do I Not Have 1000lbs Fall On Me. - Building & Construction - DIY Chatroom Home Improvement Forum
Like Tree7Likes
  • 2 Post By Nealtw
  • 1 Post By Gregsoldtruck79
  • 1 Post By ktkelly
  • 1 Post By Guardian
  • 2 Post By Guardian
Old 05-24-2018, 12:24 PM   #1
Rewards Points: 82
Idea's required - How do i not have 1000lbs fall on me.
I need to remove an ill constructed hmmmm... like a drop down ceiling shelf in the garage. I need a ladder to get to it. no idea how to remove this without it falling on me. Any ideas?
Guardian is offline   Reply With Quote
Old 05-24-2018, 12:25 PM   #2
Rewards Points: 48
Re: Idea's required - How do i not have 1000lbs fall on me.
Pics ??
Gregsoldtruck79 is offline   Reply With Quote
Old 05-24-2018, 12:49 PM   #3
Remodel and New Build GC
MTN REMODEL LLC's Avatar
Rewards Points: 528
Hire it out....????????
MTN REMODEL LLC is offline   Reply With Quote
Old 05-24-2018, 12:51 PM   #4
Rewards Points: 528
Guess you can't do it in pieces....
How about 2x4 supports as you loosen/free it..... then stand back and knockout the 2x4's....????
Old 05-24-2018, 02:24 PM   #5
Guapo
Rewards Points: 11,950
It sounds like you need temporary supports of some sort. Pics would be good.
Guap0_ is offline   Reply With Quote
Old 05-24-2018, 04:10 PM   #6
Rewards Points: 82
I finally got the picture to load. Yeah, i guess i'm going to build a temporary support. God, i wish people would use screws. It really doesn't cost that much more!!! OK, i'm going in. Wish me luck.
Old 05-24-2018, 06:56 PM   #7
Rewards Points: 48
If it were my project and working alone I would use my favorite gadget...rope and pulley. First I would remove the floor sheathing. Then knock out the blocks between the joists. Fasten the rope pulley to the old joists above dead center lengthwise of the joists to be removed. (want the joist to balance when removed and hanging in the air)
Get the rope tied around the joist to be removed and pulled tight and then anchored to a riding mower or a fat man holding the rope, that can be trusted to not just walk away and let it fall. One 16 penny nail bent over the rope on the joist being dropped down to prevent slippage... is good.
Then, knock the joist loose from the stud on each end and then lower the loose joist down slowly which will probably lay on the door tracks, where it is as least more manageable. .
Gloves, eye protection and watchful eye for nails sticking out from the removed blocks and joists ! JMO
Old 05-24-2018, 06:59 PM   #8
retired framer
Rewards Points: 4,674
With a 2x4 from the ground beat the plywood up and loose and then take it down one sheet at a time and then go after the frame one piece at a time.
ChuckF. and Mike Milam like this.
Old 05-24-2018, 07:15 PM   #9
Guapo
I would build two temporary walls perpendicular to the door. That will split the shelf into thirds. Cut in the direction of the temporary walls.
Old 05-24-2018, 07:21 PM   #10
Rewards Points: 48
Youins must have plenty of money to toss away. Why chop up good 2"x 6" boards and toss them ?
Mike Milam likes this.
Old 05-25-2018, 07:21 PM   #11
Rewards Points: 2,248
Built my 10x16 building and used nothing but screws, rather than my framing nailer.
Guardian likes this.
ktkelly is offline   Reply With Quote
Old 05-25-2018, 07:27 PM   #12
Guapo
I wouldn't use screws if I owned a nailer.
Old 05-25-2018, 07:38 PM   #13
Rewards Points: 528
Just a caution...... Screws and nails don't have the same engineering properties, and are not interchangable in many circumstances.
Screws can be darn convenient for certain projects, but most don't have the shear streanth of a framing nail.
Generally speaking, I would not frame with them.
just a comment.....
The Following User Says Thank You to MTN REMODEL LLC For This Useful Post:
raylo32 (05-26-2018)
Old 05-30-2018, 07:00 AM   #14
Rewards Points: 82
If only they had chossen 2x6's to place over my head in a span of 25 Feet!!! that would have not been to code, but i would have felt safe. No no no.. these geniuses used old pieces of 2x4 check out this photo and tell me you would leave that over your work space?
Idea's required - How do i not have 1000lbs fall on me.-33871897_10156178770005944_6887963250164498432_n.jpg
Gregsoldtruck79 likes this.
Old 05-30-2018, 07:07 AM   #15
Rewards Points: 82
It's down!!
Nealtw and Guap0_ like this.
Fireplace shelving ideas anyone?? Daddyshammer Carpentry 16 06-01-2011 09:43 PM
Need Veg Garden ideas for kids at a hospital Leah Frances Gardening Forum 2 04-21-2010 12:39 PM
Garage Ideas? tripflex General DIY Discussions 13 12-16-2009 08:06 PM
Dining room renovation - looking for ideas hyunelan2 Interior Decorating 1 10-10-2009 07:03 AM
Wooded lot - Fall overseeding in NC HomeinNC Landscaping & Lawn Care 10 10-04-2009 12:19 PM
