Ideas On How To Create A Water Run Off For Cabana Top (pics) - Building & Construction - DIY Chatroom Home Improvement Forum
Old 07-26-2010, 12:10 PM   #1
Ideas on how to create a water run off for cabana top (pics)
Hey guys I had a upholsterer make me a cabana top and curtains which came out great....... my problem is when it rains since the material is water proof all the water pools in the middle on top and caves in the top and pulls up the curtains............ what would be one way of possibly making a little raise through the center of the top so water runs off the sides? I was thinking maybe run 2 more beams through the center of the wood frame but have it raised up 5 inches? would that be enough any thoughts?
Ideas on how to create a water run off for cabana top (pics)-34034_565092169027_42604075_32894425_7220419_n.jpg   Ideas on how to create a water run off for cabana top (pics)-34034_565092174017_42604075_32894426_2592324_n.jpg
Negativecreep0 is offline   Reply With Quote
Old 07-26-2010, 02:13 PM   #2
Rewards Points: 5,348
The roof needs to be inclined and the material on top needs to be taut to shed water. Material isn't the best product. You can put a shed roof on or a gable roof on or a centrally peaked roof on. This will shed water with a rigid roof material. The snow load is another issue. Once you start with roofing, you need it to carry everything your region will throw at it.
Ron
How to properly drain and flush a hot water heater? speedster1 Plumbing 9 04-17-2012 09:55 PM
A blocked water line causing water to loose heat? Snav Plumbing 6 05-07-2010 02:18 PM
Kitchen Faucet Cold Water Runs Hot Mthrboard Plumbing 8 08-02-2009 06:59 AM
Very Low Hot Water Pressure. PAS1970 General DIY Discussions 2 02-25-2009 03:01 PM
(Water Heater MYSTERY) Hot water out from dead tank with cold water in it? Inayity Plumbing 6 07-14-2008 08:36 PM
