How To Split Payments For Finishing Attic? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 08-06-2014, 04:50 PM   #1
Rewards Points: 31
How to split payments for finishing attic?
Finishing an unfinished attic including building an bathroom will cost $12,000. The homeowner plans to make four 25% progress payments for the project. The first 25% is the down payment. The last 25% payment is for the punch list complete and final release of all liens. Is it ok? If so, can you help to arrange the other two 25% or one 50% payment in the middle? Is it paid after the completion of drywall, bathroom/ plumbing fixtures set but only leave the installation of the carpet or what else? Thank you for your answer.
compiler is offline   Reply With Quote
Old 08-06-2014, 05:47 PM   #2
Tileguy
Bud Cline's Avatar
Rewards Points: 558
It is all negotiable, there is no real standard or practice. You can figure it out on your own by offering and coming to an arrangement everyone agrees with.
XXX
The Following User Says Thank You to Bud Cline For This Useful Post:
r0ckstarr (08-06-2014)
Old 08-06-2014, 06:48 PM   #3
r0ckstarr's Avatar
Rewards Points: 82
What is the start date and estimated completion date on the contract? Work out something with the builders based off of those dates.
r0ckstarr is offline   Reply With Quote
Old 08-06-2014, 11:01 PM   #4
Msradell's Avatar
Rewards Points: 912
That's definitely not a good way to spread out progress payments! Indeed to be based on the amount of work complete, not the amount of time taken.
Written using Dragon Naturally Speaking
Msradell is online now   Reply With Quote
Old 08-07-2014, 12:25 AM   #5
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Be careful determining payments based on "percentage of completion," that can also be a sticky wicket. Who is to determine the percentage and who has the final say should there be a disagreement, should be a part of that type of agreement.
XXX
Old 08-07-2014, 08:55 AM   #6
Ole Wood Worker
BigJim's Avatar
Rewards Points: 260
$12,000, must be a very small job, a bath can cost that alone.
Holding 25% on the final would bother me, 10% is more like it in my book. They could ride it out for a long time holding that 25%.
New members: Please consider adding your location to your profile.
Lawyers believe a man is innocent until proven broke.
If you do what you've always done, you'll get what you've always got.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is online now   Reply With Quote
The Following User Says Thank You to BigJim For This Useful Post:
woodworkbykirk (08-07-2014)
Old 08-07-2014, 09:09 AM   #7
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Twenty-five percentage retainage is way over the top, 10% is more customary. I wouldn't allow any retainage, hell that's your money if you see that much when your finished, why would you want to wait for it any more than five minutes past completion?
Old 08-07-2014, 09:38 AM   #8
Residential Designer
AndyGump's Avatar
Rewards Points: 874
Send a message via Skype™ to AndyGump
Where are you located? Namibia?
$12,000.00 doesn't seem like much for the scope of work you stated.
Andy.
Residential Drafter/Designer
www.draftinginoc.com
AndyGump is offline   Reply With Quote
Old 08-07-2014, 09:34 PM   #9
Msradell's Avatar
Rewards Points: 912
It's certainly better than setting a length of time like the previous poster mentioned. Actually maybe percentage was a bad word to use, I was thinking of at certain milestones such as framing complete, sheet rock complete, electrical rough in complete and approved, etc.
Tags
payments schedule
Attic insulation simagic Insulation 1 05-07-2014 01:06 AM
Attic insulation suggestions? iwfur25 Insulation 1 07-09-2012 12:50 PM
Attic Insulation tim1218 Insulation 4 09-07-2011 11:18 AM
Ventilating attic with two roofs senorbungle Building & Construction 2 01-09-2011 05:17 PM
Frost in the Attic 295yards General DIY Discussions 13 12-07-2009 05:27 PM
