How Soon After Lieing Block Can You Tar For Weatherproofing - Building & Construction - DIY Chatroom Home Improvement Forum
Old 02-20-2011, 09:16 AM   #1
how soon after lieing block can you tar for weatherproofing
i just built a fence wall on the line of the nation forest and wanted to beplace dirt on that side how soon after building the wall can i tar the bottom courses .
wayne beresford is offline   Reply With Quote
Old 02-20-2011, 09:20 AM   #2
are you supplying drainage easement at bottom of wall? Depending on temp couple days to a week
The older I get the better I was
Old 02-20-2011, 09:54 AM   #3
thanks for the info
yes every other block on grade will be open
Vinyl Window in Concrete Block Wrongwrench Carpentry 4 12-07-2010 10:21 AM
Door opening in load bearing block wall SS396 Building & Construction 12 09-13-2010 05:27 PM
Fire blocking a wood stud wall built against cinder block. BasementVirgin Building & Construction 1 10-05-2009 11:02 PM
Cracks In Block Wall Foundation vf100 Building & Construction 7 08-20-2008 09:48 PM
Marrying a sloping stone wall to a cinder block wall. mrdol Landscaping & Lawn Care 1 11-09-2007 04:08 PM
