How Should I Cover My Crawlspace? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 08-22-2019, 01:54 PM   #1
Rewards Points: 4
How should I cover my crawlspace?
So I'm remodeling my laundry room (a small room in between our kitchen and back porch). I'm trying to figure out the best way to cover the sides of the crawlspace so that the pipes don't freeze and rodents stay out. There is no concrete footing all around it. It sits on concrete pillars. Thanks!
rezajafshari is offline   Reply With Quote
Old 08-22-2019, 01:56 PM   #2
retired framer
Rewards Points: 1,512
Re: How should I cover my crawlspace?
Can you post a picture or two?
And welcome to the site.
Do not use flat bottom gables with scissor trusses.
Old 08-22-2019, 02:50 PM   #3
Rewards Points: 4
Here's a photo:
Old 08-22-2019, 06:00 PM   #4
Hammered Thumb
Rewards Points: 454
Whatever material you choose you will not want that touching the dirt. It will also be hard to detail around the sonotubes. I would guess you have to have an access panel as well? And there will be some holes in the main foundation wall for HVAC/plumb/elec to cross into the main house? Since its a small area, I might consider a trench footing to keep the inside ground and the cover panels dryer, and allow you something to fasten the bottom to.
In other news, if you raised your wall before subflooring, you might have to rip 5/8"+ off the drywall if its a standard 92 5/8" stud length (or raise the top plate).
3onthetree is online now   Reply With Quote
Old 08-22-2019, 06:33 PM   #5
retired framer
Originally Posted by rezajafshari View Post
Here's a photo:
I would fill the joist space with insulation and then staple up a bug screen and then a critter screen.
https://www.amazon.ca/Phifer-3002527...15102232&psc=1
https://www.amazon.com/Hardware-Galv.../dp/B015PD9IOU
Tags
crawlspace , foundation
