How To Repair A Cut Truss..... - Building & Construction - DIY Chatroom Home Improvement Forum
Old 01-27-2019, 05:55 PM   #1
Doing it myself
Alan's Avatar
Rewards Points: 2,140
How to repair a cut truss.....
So this is something I missed during my walkthrough of this house, but somebody installed an attic ladder (pretty nice old wooden one) and in the process decided that since there was a truss where they wanted it to go they would just chop out the middle of it.
It wouldn't be so bad except for every time I want to go up there I have to climb around the web to get up. I also know that while it will probably stand this way for a long time it isn't really right and i'd like to fix it.
TYIA
Journeyman Plumber
Old 01-27-2019, 05:58 PM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 6,640
Re: How to repair a cut truss.....
Pictures.
You can typically box them out and brace the cut out sections on the adjacent. Usually if there is an issue with a delivered truss, the engineer ways in and puts his mark on it. We have had several arrive with broken top chords that require sistering with plywood on both sides to stabilize.
Old 01-27-2019, 06:00 PM   #3
retired framer
Rewards Points: 1,484
TYIA
Best if you could move it to where you have the required 22 1/2" space.
Can you post a picture. Or two.
Old 01-27-2019, 07:42 PM   #4
Doing it myself
Alan's Avatar
first view from below showing the web impeding entrance to the attic.
https://drive.google.com/open?id=1Rq...b4GI3IfiNHBpd2
Second view showing the web and the king post connection as well as the distance the bottom chord is cut from that connection.
https://drive.google.com/open?id=1bO...RiGpUikGVJnxM9
Third view showing the connection between the bottom chord and the "header" and the connection between that and the bottom chord. No hanger or reinforcing plates of any kind on any of these.
https://drive.google.com/open?id=1GC...xpQABMNqKcKFt3
The other side of the ladder is nearly identical, except it isn't near the king post.
Journeyman Plumber
Old 01-27-2019, 08:53 PM   #5
retired framer
Your trusses are a 16" on center, I have only done that once and they had us leave one opening wide enough for and access.
So when it was built the access was only 28 or 30 inches long and someone has made if longer for that ladder. If you turn the ladder around so you are climbing the other, would that make it better.
A few things that should be mentioned.
Those trusses were not built for a floor up there.
Or storage of any kind.
The paper faced insulation is upside down.
I am not sure what else you could do to make it better. You might take the pictures to any truss company for a suggestion.
Old 01-28-2019, 01:52 AM   #6
Doing it myself
Alan's Avatar
They are actually 24" on center, and the ladder would have worked perfectly had they put it between the trusses. I'm not sure what happened there. If I turn it a 180, i'll just be hitting the web on the other side of the truss, and the headspace will be even lower as the roof slopes downward in that direction.
I do understand the concept that the attic spaces are not for storage of any kind. I do sort of break that rule a bit and put some light weight stuff up there like my christmas ornaments and sleeping bags for camping.
Growing up my parents had metric tons of things in their attic space (still do to this day) and the roof structure hasn't suffered any apparent damage, so I don't really feel unsafe putting some light boxes in my garage attic.
Journeyman Plumber
Old 01-28-2019, 02:42 AM   #7
retired framer
Hard to imagine what they were thinking and if you want to move it making a repair with floor and ceiling in place would be hard, did they put the header right across so you could just move it over?
Sheet rock and truss uplift jklingel Building & Construction 13 01-04-2013 10:46 PM
Gable End Truss Offset Siding ChristianT Carpentry 7 07-29-2011 04:54 PM
Choosing a Refrigerator based on Repair Value 1655graff Appliances 5 03-01-2011 09:49 AM
Truss uplift repair for parallel wall wvphysics Drywall & Plaster 4 11-20-2010 02:54 PM
Adding more weight to truss system... what can it hold? Sonnie Building & Construction 7 02-06-2009 09:45 PM
