How To Protect Against Carpenter Bees - Building & Construction - DIY Chatroom Home Improvement Forum
Old 07-09-2018, 06:27 PM   #1
Rewards Points: 2
How to protect against carpenter bees
Carpenter bees are boring into my header board on front porch. I have some traps but they have only caught a few. All of the suggestions that I have found online give suggestions on various ways of killing them after they have bored the hole.
Are there methods of preventing them from boring in the first place?
joshbsg is offline   Reply With Quote
Old 07-09-2018, 06:46 PM   #2
Rewards Points: 1,251
Re: How to protect against carpenter bees
Don't have exposed wood on your house.
I have wood all over my house and the carpenter bees love it. Oddly, I saw several in the spring when we had several unusually hot days. We then had a few days of freezing weather and I haven't seen one since. I even installed some traps to catch them this year and there are none to catch.
KHouse75 is offline   Reply With Quote
Old 07-09-2018, 07:00 PM   #3
Rewards Points: 18,382
Spray the exposed wood with Timbor.
Google it.
I make up my own mix of "Roach Away" powder, hot water and a dash of dish soap and use a pump sprayer.
It contains 95% Boric Acid, which is to used to kill many kinds of insects
Old 07-09-2018, 08:43 PM   #4
Rewards Points: 9,406
They seem to prefer to come in from the bottom, and seem to prefer the rim boards. Although I expect joists are at risk also.
By deck's rim joists are ipe, but joists are pressure treated softwood. I have read that stain won't slow them down, but a oil based paint will stop them. Taking the "if a little is good, a lot is better" approach, I painted the bottom of my deck joists with brush-on roofing tar. Seems to work.
Of course, first you need to kill the ones that are in there.
SPS-1 is online now   Reply With Quote
Old 07-09-2018, 10:26 PM   #5
Rewards Points: 1,900
I have a can of Raid with the little tube on the spray head that can swivel to point straight up. One little squirt, five seconds of furious buzzing, then quiet. Fill with caulk after a couple days.
ChuckF. is offline   Reply With Quote
expanding foam to stop carpenter bees nikeman Pest Control 10 05-24-2014 11:17 AM
Carpenter bees will infest pressure treated wood downunder Pest Control 0 05-08-2011 12:49 PM
