How Much Weight Can 2 Studs Support? - Building & Construction - DIY Chatroom Home Improvement Forum
Like Tree3Likes
  • 1 Post By ront02769
  • 1 Post By House Designer
Old Yesterday, 09:07 PM   #1
Rewards Points: 6
How much weight can 2 studs support?
Hello,
Im planning on installing a chin up bar wall mount in my basement. Its an unfinished basement so i know where the studs are. I was just curious if this was a good idea. When i opened the box the chin up bar seemed really heavy alone, plus me hanging on it. The chin up bar has atleast 3 screws on each side, so basically 3 screw hole for each stud.
Just wondering how much weight can 2 wood studs support? Or should i screw in a sheet of plywood to make it more secure?
Arcflasher1 is online now   Reply With Quote
Old Yesterday, 09:14 PM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 9,496
Re: How much weight can 2 studs support?
About 1,000 lbs a pop if they are squared up.
Old Today, 03:44 AM   #3
Rewards Points: 4
Can we use additional screws to make it more secure?
Merc_j is offline   Reply With Quote
Old Today, 04:58 AM   #4
Naildriver
chandler48's Avatar
Rewards Points: 1,738
Who is "we"? More screws will only degrade the holding capability of the adjacent screws. Don't modify the screw pattern.
Larry......
Half of Communications is Listening, and You can't Listen with your Mouth.
chandler48 is offline   Reply With Quote
Old Today, 06:43 AM   #5
Rewards Points: 9,712
Mounted to studs, or ceiling joists ?
In either case, if you are not comfortable with the loading, you can mount a 1" plywood sheet across multiple studs to distribute the load to more studs. You could then mount the pull up bar to the plywood with nuts and bolts, which eliminates the risk of pull up bar screws pulling out of the wood.
SPS-1 is online now   Reply With Quote
Old Today, 08:10 AM   #6
Rewards Points: 1,790
Just attach it per manufacturers instructions and be done with it. Mine is still up 30 years later.
Nealtw likes this.
ront02769 is online now   Reply With Quote
Old Today, 11:40 AM   #7
Endless Projects
Rewards Points: 1,584
If you weigh more than 1000 lbs don't think you will be doing any pull ups.
If you wanted to reinforce something. You could add another stud or portion of a stud inside the framing. Look at this link and think of the trimmer stud.
https://www.shedking.net/shed-door-window-framing.html
Photobug is online now   Reply With Quote
Old Today, 11:46 AM   #8
Endless Projects
A chin up bar on a wall will be nearly useless. You need room to swing it needs to be in a doorway. If you have a door jam you can also get a pull up bar with multiple positions that can be hung temporarily as needed in the doorway. If you want to hang it not in a doorway a ceiling joist would be better.
A lag bolt vs screws would increase holding strength. You will need to buy or borrow a stud finder to find the stud or ceiling rafter location. Another way is to find a power outlet or switch. They will likely be mounted on a stud and the next stud will be 16 inches on center away.
Old Today, 04:09 PM   #9
House Designer's Avatar
Rewards Points: 98
Originally Posted by Arcflasher1 View Post
Hello,
The correct answer to your question is that no definite answer is available because your problem is under-defined.
A 2x4 stud is rated to carry 529 lbs. if it is 8 ft tall and loaded as a column at the 8 ft height. Loaded at any shorter height, the capacity increases.
Each #8 wood screw is rated to carry 108 lbs. in single shear, when screwed into a 2x4 with 2" of penetration.
Your problem needs the height of the pull-up bar defined, and also the number and size of the wood screws defined. Also need to define the geometry of the pull-up bar.
i.e we would need to know how far the pull-up bar is cantilevered from the wall, and the exact location of the screws, because the cantilever amplifies the load on the screws and puts those screws in tension instead of shear.
House Designer is offline   Reply With Quote
Old Today, 04:44 PM   #10
Your problem is actually easy to answer. Hang per mfgr’s. Instructions and pull away! Over-analyzing.
Nealtw likes this.
Old Today, 04:53 PM   #11
Rewards Points: 98
Yes, absolutely! When all else fails, read and follow the mfgr instructions. They engineered it to work.
Nealtw likes this.
Old Today, 10:08 PM   #12
Rewards Points: 6
Thanks everyone!
