How Much Gap To Leave Between Hardiplank Siding And Trim Boards? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 12-16-2009, 07:57 PM   #1
Rewards Points: 45
How much gap to leave between hardiplank siding and trim boards?
How large should be gap be between the hardiplank and the trim boards that it will butt up against?
kooshball is offline   Reply With Quote
Old 12-16-2009, 08:11 PM   #2
Tom Struble's Avatar
Rewards Points: 2,002
i usually try for 3/16'' or so
Tom Struble is offline   Reply With Quote
Old 12-17-2009, 06:44 AM   #3
Tom- Just to follow-up, do you then caulk the gap or not necessary?
stubits is offline   Reply With Quote
Old 12-17-2009, 07:25 AM   #4
Rewards Points: 45
Most of the caulk companies are asking for a 3/8" bead but that seems huge for a such a gap to be filled with caulk.
Old 12-23-2009, 08:02 PM   #5
yes always caulk where the panel butts the trim
Old 12-23-2009, 08:03 PM   #6
3/8 bead is different than a 3/8 gap
Old 12-23-2009, 10:09 PM   #7
Registered User
Rewards Points: 526
Be safe, Gary
Old 12-23-2009, 10:16 PM   #8
Registered User
Rewards Points: 526
3.2.G Allow 1/8 inch gap between Hardietrim fascia and moulding to siding. From: http://lowes.jameshardie.com/homeown...al/default.htm
Remember to prime, paint, or smear caulking on any cut ends or rips as per manufacturer or void warranty. Slightly different installation instructions for different areas: http://www.jameshardie.com/homeowner...nkLapSiding.py
With big gaps, or dis-similar materials (cement siding and wood corners), pages 28 and 41- backer rod first: http://books.google.com/books?id=fDs...age&q=&f=false
Be safe, Gary
Vinyl Siding Not Locking In Place Konfrst Building & Construction 13 11-17-2009 09:40 PM
What trim is more water resistant and holds paint better: Miratec or Smart Trim? Studly Building & Construction 4 10-03-2009 07:45 AM
Vinyl Siding 45^ angle trim diy man Building & Construction 1 09-20-2008 04:53 AM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 1 03-19-2005 12:55 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 0 04-18-2004 03:35 PM
