How Much To Fix This Or How Difficult To Do Myself? - Building & Construction - DIY Chatroom Home Improvement Forum
Like Tree1Likes
  • 1 Post By Windows on Wash
Old 04-16-2017, 09:32 PM   #1
Rewards Points: 14
how much to fix this or how difficult to do myself?
any advice on how to approach this I think this is rotting rim joist caused by some sort of water drainage problem in this corner of house I think from the conduit box wire going through the rim joist. It is about 5' of rim board. The sill plate looks like it is in good shape and its only the outside rim board.
deck will have to be taken apart , some siding off and replaced...
and then I probably should invest in eavestroughs to keep rain away from foundation however, i have some erosion on the grass under roof line, and where rain runs off roof and hits deck the deck is a different color in a line pattern around roof line... so that corner gets alot of water...
How much will this cost to repair any ideas/how many days would it take? i am getting some quotes tomorrow.
Pictures - i circled the problem area, a close up of good wood/bad wood, a close up of rot some sort of white goo on it
of course home insurance doesnt cover anything water related so im guessing this will be tonnes of money to fix...
how much to fix this or how difficult to do myself?-deck2.jpg   how much to fix this or how difficult to do myself?-deck1.jpg   how much to fix this or how difficult to do myself?-deck3.jpg   how much to fix this or how difficult to do myself?-deck4.jpg   how much to fix this or how difficult to do myself?-deck5.jpg
staffpro is offline   Reply With Quote
Old 04-16-2017, 10:05 PM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 6,692
Re: how much to fix this or how difficult to do myself?
Impossible to say, but you are correct in that it is not going to be a small undertaking.
Be sure to check the flashing at the ledger board and under that door in conjunction with fixing that valley/gutter detail to keep the water out of that corner.
Old 04-17-2017, 08:48 AM   #3
MEASURE ONCE, CUT TWICE
123pugsy's Avatar
Rewards Points: 1,438
Yep. Some eaves troughs will help. Never seen aluminum on a house finished without eaves troughs installed.
And what the heck is that alien goo? It must be some kind of fungus/mold.
If you can do it yourself, only you know your capabilities with tools.
Pugsy...my project: http://www.diychatroom.com/f49/total...storey-276978/
123pugsy is offline   Reply With Quote
Old 04-17-2017, 09:43 AM   #4
The goo is spray foam.
Old 04-17-2017, 10:00 AM   #5
123pugsy's Avatar
I see that, but check the last pic. Looks like fresh freaky stuff...
Old 04-17-2017, 11:16 AM   #6
Rewards Points: 14
ya that goo is not spray foam it is indeed some kind of growth this is on outside....
on inside ive spray the area with borax, 90% alcohol, and oxyclean and just let it dry until it gets fixed to hopefully kill any spores, a few days before that when i first discovered it i sprayed the area with undiluted bleach. Hoping that prevents any issues with spread .
Old 04-17-2017, 04:44 PM   #7
I would just hit it with bleach and water.
123pugsy likes this.
Old 04-23-2017, 10:34 PM   #8
Rewards Points: 14
one contractor came looked at it and told me not worth it to replace it. He is doing my eavestroughs and he said likely the eavestroughs will divert water away from house and he said its the "aspenite" sheathing and not the inside rim board, and to javex it and then run a dehumidifier in the crawlspace to dry it out from the inside. what do you guys think. the hosue didn't have eavestroughs for 6 years which likely did cause the problem.
Old 04-24-2017, 06:08 AM   #9
123pugsy's Avatar
You need eaves troughs no matter what, so the plan is very good.
You can see the effect after the eaves troughs are done and it's dried up.
Removing/installing microwave over cooktop - difficult? andyscott Appliances 13 12-16-2014 10:49 PM
How difficult is it to find a leak Clutchcargo HVAC 16 06-12-2013 07:04 PM
Advice needed on difficult PVC repair (photo) halliwellc Plumbing 5 09-13-2012 10:14 AM
Single lever kitchen faucet (Moen) difficult to move repairlady Plumbing 2 03-02-2011 07:16 AM
How difficult is 8 AWG wire to work with? PirateKatz Electrical 13 02-16-2009 01:05 PM
