How To Measure A Large Arc? - Building & Construction - DIY Chatroom Home Improvement Forum
Like Tree5Likes
  • 1 Post By Bud9051
  • 2 Post By Nealtw
  • 1 Post By Darkkhelmet
Old 07-22-2018, 06:26 PM   #1
Rewards Points: 36
how to measure a large arc?
I'm working on a porch roof that has a large decorative arc fascia that originally had nothing behind it. I have removed three posts and installed a header that will be supported by two posts. Is there a simple way to measure the open arc so I can cut a filler for it? Once complete the header and fascia will be covered with aluminum.
Darkkhelmet is offline   Reply With Quote
Old 07-22-2018, 06:41 PM   #2
kwikfishron's Avatar
Rewards Points: 186
Re: how to measure a large arc?
Just hold a board up behind it and scribe it and then cut it.
kwikfishron is online now   Reply With Quote
Old 07-22-2018, 06:42 PM   #3
Rewards Points: 36
Originally Posted by kwikfishron View Post
Just hold a board up behind it and scribe it.
The header is behind it.
Old 07-22-2018, 06:55 PM   #4
Rewards Points: 8,172
Tape up a long piece of paper or several 8.5 x 11 sheets taped together. Then sketch over it with the side of a pencil like the investigators do when recovering the indentations made by the writing on the sheet above.
Give that your best freehand line and it will be very close. Use that to cut a piece of cardboard if you want to test.
Or, if you have a nice piece of cardboard apply some paint to that arch and press the cardboard against it. Many way to skin this cat.
Bud
stadry likes this.
Bud9051 is offline   Reply With Quote
The Following User Says Thank You to Bud9051 For This Useful Post:
Darkkhelmet (07-22-2018)
Old 07-22-2018, 10:33 PM   #5
JUSTA MEMBER
Rewards Points: 1,670
Like bud says, many ways to skin it.
A 1X4, long enough to span the area, and even a Bingo dauber to mark the edge of the arc, place the 1X4 against the area, magic, you have a template.
ED
de-nagorg is offline   Reply With Quote
Old 07-22-2018, 11:03 PM   #6
retired framer
Rewards Points: 6,418
If you are wrapping it, what is the filler for.
Cut the bottom few inches off and put a 1x2 flush with bottom of the beam.
Or put a board on the bottom of the beam over flush with the outside of that board.
Colbyt and Bud9051 like this.
Old 07-22-2018, 11:05 PM   #7
Rewards Points: 322
Measure the distance between the termination points from say left to right where the arch terminates.
Than on the piece of wood you will cut the arch from place a nail at the left point than measure over & place a nail at the right point.
Now with a piece of string go around both nails and tie a knot keeping the string tight make sure the knot is located bottom at the center of the area to be cut out than with a pencil start at the Left with the pencil inside the string and pulling the string tight pull the pencil to the Right nail point. This should give you the arch between the two points.
ClarenceBauer is online now   Reply With Quote
Old 07-23-2018, 09:00 AM   #8
Rewards Points: 36
The filler is for screws for plant hangers once the job is done.
The Following User Says Thank You to Darkkhelmet For This Useful Post:
Nealtw (07-23-2018)
Old 07-23-2018, 09:05 AM   #9
Rewards Points: 36
Thanks everybody for the great suggestions. I'm sure I can get it done now.
Bud9051 likes this.
Old 07-23-2018, 09:17 AM   #10
retired framer
Tape paper up high so it hangs down over it. Lift the paper and apply lipstick to the face of the curve and smooth the paper over the curve and you have a pattern.
Hang clear plastic the same way and mark the curve with a sharpie.
Old 07-23-2018, 09:48 AM   #11
ZTMAN's Avatar
Rewards Points: 492
Then hold the board to the front, and scribe from the rear.
I don't mind spending money, I mind wasting money.
ZTMAN is offline   Reply With Quote
Old 07-23-2018, 12:19 PM   #12
retired framer
Not enough room with beam up against the back.
But he could hold a board up and spray paint in to the void.
Old 07-23-2018, 04:21 PM   #13
Rewards Points: 36
Such great ideas. And Nealtw, I think I misunderstood your suggestion when I first read it. The neighbor that's in construction that's helping nailed the existing boards to the header so cutting them straight may be an issue but I like the solution. I purchased some sidewalk chalk in case it's too difficult to remove the lower half of the fascia. I'll use the chalk to imprint the arc onto the new piece of wood.
Nealtw likes this.
@ large windows into large double slider patio door BillyBaldwin Building & Construction 4 05-11-2018 10:01 AM
Unused large central closet to become Laundry room. Soupcatcher Plumbing 1 08-06-2010 05:01 AM
Suspended Ceiling - measure up or down? Woodcutter Remodeling 8 02-28-2009 06:53 AM
How to measure for new pre-hung interior doors jencampo Carpentry 3 03-25-2008 01:49 AM
How to measure windows for new construction? pastrami Remodeling 1 04-26-2007 08:36 PM
