How To Mark Oval Hole For Flue Penetration - Building & Construction - DIY Chatroom Home Improvement Forum
Old 11-20-2009, 02:52 PM   #1
How to mark oval hole for flue penetration
Sealing a ceiling penetration for a hot water heater flue on a slanted ceiling. What's the easiest tip/trick for transferring the measurement for a round flue pipe onto the sheet metal, where the cutout will have to be an oval due to the slant of the ceiling?
I know there has to be an easy way to do this! And I'm sure it will work better and get a tighter fit than my trial and error method would!
Thanks.
akguy is offline   Reply With Quote
Old 11-20-2009, 03:00 PM   #2
Super Moderator
joed's Avatar
Rewards Points: 31,936
Hold the flue vertical touching the ceiling. Mount a pencil on a stick. Hold the stick tight and vertical on the flue pipe and go around the pipe moving the stick up and down as required.
Or cut a section of flue pipe (or something of similar diameter) off at the same angle as the ceiling then you can push it up tight and draw the line.
Old 11-20-2009, 03:02 PM   #3
Thank you! That seems SOOOOO obvious now that I see it.
Problem Patching Large Drywall Hole FuLLTiLT Drywall & Plaster 5 11-21-2009 09:42 PM
How to patch hole in duct work and drill new one? Studly HVAC 10 03-03-2009 09:26 AM
A Hole to Nowhere fw2007 Electrical 12 03-24-2008 10:28 AM
Making an 8" hole in the brick Hushpuppy Building & Construction 6 11-28-2006 07:17 AM
