How To Insulate Under A Balcany Over Living Space With No Vents And Soffits? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 06-16-2010, 09:03 PM   #1
How to insulate under a balcany over living space with no vents and soffits?
Hi, I was wondering if someone can help me with insulating under my balcany over living space ? I'm from calgary ab canada and its cold up here. I think I would have to spary foam the whole cavity with 7" of 1/2lb foam and coated with 2lb foam to tie in vapor barrier(r34 total rating). The reason i'm doing this is that I have no vents or soffits. Is there another way of inslating this area with out foam that is up to code and won't condensate?
thanks
How to insulate under a balcany over living space with no vents and soffits?-scan0001.jpg
magna is offline   Reply With Quote
Installing Soffit vents w/finished attic Nathan0115 Roofing/Siding 6 06-04-2010 09:05 PM
New house, ridge vents and no soffits arlon Roofing/Siding 3 05-20-2010 08:05 AM
Powered Attic Fan question spup345 Roofing/Siding 9 06-30-2008 08:10 PM
