How To Extend Wall Vertically - Building & Construction - DIY Chatroom Home Improvement Forum
Old 10-21-2009, 03:43 PM   #1
How to Extend Wall Vertically
I'm new to this site and DIYing in general, we are closing on our house at the end of the month and there are some things we would like to change.
Currently we have a large island in our kitchen (see attached pictures) and would like to raise a portion of it so that it is a bar which we could eat at. There is a short wall (I think the term is pony wall) currently on the other side of the cabinets and that wall is what we would like to make taller. Is there a way to do this without tearing out the current wall and just building a new one which is taller. We will be putting granite counter tops in eventually so I don't know if that changes the answer at all.
Thanks for all of your advice in advance.
-Kyle
How to Extend Wall Vertically-kitchen.jpg   How to Extend Wall Vertically-kitchen2.jpg
vision646 is offline   Reply With Quote
Old 10-21-2009, 11:09 PM   #2
Registered User
Rewards Points: 526
You could just screw some 3"x3" L-brackets (3-each side) on the top of existing wall, add a built-up header of 2-2x6's and 1/2" ply in between, then a 2x4 top plate to add 7" = 43". And remove the drywall face opposite the cabinets to install solid wood horizontal blocking between studs at the tops on the ends for corbel backing to support the counter-top later. Put a wood veneer on the drywall for children to kick at without punching holes under the cantilever.
Be safe, Gary
Removing a 4 foot opening in a load bearing wall (for fish tank) ~callie~ Building & Construction 1 07-15-2009 05:10 PM
Low Retaining Wall cibula11 Landscaping & Lawn Care 3 07-29-2007 12:02 AM
