How Do You Convert From Different Fastener Measuring Systems? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 06-11-2009, 06:37 PM   #1
How do you convert from different fastener measuring systems?
When i go to the store , you see #6,#8,etc. also M6,M5, 1/4" etc.. Is there some conversion factor between them?
gomerpyle is offline   Reply With Quote
Old 06-11-2009, 08:02 PM   #2
Remodeling Contractor
not exactly. the threads on the M6 are different then the ones for the English equivalent. A M4 is almost the same as a 8/32" but you cannot use one in place of the other.
Old 06-11-2009, 09:44 PM   #3
DIY Hack
Mr Chips's Avatar
Rewards Points: 506
You can't really convert for thread pitch, but you can for diameter. A #10 wood or sheetmetal screw is approx the same as a 3/16 threaded screw (aka 10-24 or 10-32 depending on thread pitch). A number 5 wood screw is about 1/8", which is close to a metric M4 diameter. it can be confusing for sure....
Mr Chips is offline   Reply With Quote
Whole House Water Treatment Systems HWPipes Plumbing 21 04-25-2013 08:53 PM
Comparison of subfloor waterproofing systems formarley Building & Construction 5 10-22-2009 10:03 AM
Ductless mini-split A/C systems bayouelton HVAC 3 08-02-2008 08:15 PM
convert wood fireplace to gas fireplace brisk Building & Construction 3 06-19-2008 08:17 AM
Compairing PEX Manufactures and Systems recumbent615 Plumbing 2 04-02-2008 05:18 PM
