How Did This Stain On My Ceiling Get There? - Building & Construction - DIY Chatroom Home Improvement Forum
Like Tree1Likes
Old 03-27-2017, 01:27 PM   #1
Property Mgt/Maint
Rewards Points: 7,116
Re: How did this stain on my ceiling get there?
The nails could have worked loose over the years. Freeze and thaw cycles can easily work nails loose. I believe the mfg calls for nail spacing at 4 or 6". Can not tell yours from the underside photo.
It can be repaired. Not sure about doing it without destroying the shingle caps though. If it's just the one spot I would probably try to add longer nails in that area. If its all along the ridge, then tear it off and re-do.
Yodaman is online now   Reply With Quote
Old 03-27-2017, 01:33 PM   #2
Rewards Points: 1,052
I have a roofer stopping by. The vents are up in several places.
I have a few extra shingles, but not enough to do anything. There is writting on the back. Can new shingles be bought from that?
Where are you in upstate NY?
Toller is offline   Reply With Quote
Old 03-27-2017, 07:07 PM   #3
Property Mgt/Maint
Looks like when the mods moved this thread it was also broke apart.
Regarding the shingles. Should be easy to find a suitable match, even if not able to identify. It gets tricky when you need to weave in new along with old on the roof deck itself. As long as the entire ridge is the same shingle, a slight color change from the roof should not be noticeable.
On the southern border, half way across
stain yellow pine T&G patio ceiling J.E.D. Painting 2 11-16-2016 11:31 AM
Paint peeling off Bathroom Ceiling!!! armen30 Painting 17 12-08-2011 09:26 AM
Popcorn Ceiling Stain? RDLearned Painting 13 09-21-2011 11:44 AM
Water stain on ceiling jend300 Plumbing 3 09-21-2009 08:09 AM
Ceiling Leak Stain Repair Help Please ltkenbo General DIY Discussions 2 09-13-2009 07:38 PM
