How Can I Remove This Board Without Destroying It? - Building & Construction - DIY Chatroom Home Improvement Forum
Like Tree2Likes
  • 1 Post By Gary in WA
  • 1 Post By Rav
Old 01-09-2017, 11:28 AM   #1
Rav
Rewards Points: 884
How can I remove this board without destroying it?
House built in 1930. See attached picture of a small closet whose back and right side walls are right up against the outside of the house. The closet is very cold inside and I've determined that air is leaking up through the raised "floor" on the bottom of the closet. I was able to peek through one of the cracks in the three wide floor boards and can see that there's open space under there where some sealing and insulating could help a lot. If I could remove one of those floor boards I would have access. They are nailed down with finishing nails, of course. I'm able to get a wide chisel scraper under that front board, but can't loosen the nails by just lifting up. There's also a small gap between the first and second boards.
Is there a way to remove that board (or perhaps the middle board) without destroying it? I have to be able to re-use it. Any special tools for removing the nails, or ??? Thanks.
Rav is offline   Reply With Quote
Old 01-09-2017, 11:58 AM   #2
JUSTA MEMBER
Rewards Points: 1,612
Re: How can I remove this board without destroying it?
There's a hand tool called a CAT'S PAW , used to carefully remove the nails.
Takes patience and a brain to operate.
ED
de-nagorg is offline   Reply With Quote
Old 01-09-2017, 12:53 PM   #3
Registered User
Rewards Points: 526
Cats-paw is great for nails with heads. Nail set or pin punch would work better for your finish nails in this case, IMO. 3/4" board= nail set. 1-1/4" board or larger= pin punch. Add some rigid foam board and caulk/seal around the edges per energy code per location.
Gary
BigJim likes this.
Old 01-09-2017, 01:35 PM   #4
Super Moderator
joed's Avatar
Rewards Points: 30,568
If they are finish nails you can use a punch of the same size and punch them through the board releasing it.
Old 01-09-2017, 02:05 PM   #5
Rewards Points: 8,142
If you have access from below, crawlspace of basement, do what you can to air seal and insulate that exterior area. I realize older homes may not make that easy or at all possible, but wanted to mention it.
Being cold in that cabinet is not just due to the floor. Closets or under stairs spaces have the same problem in that the closed space is isolated from the heat.
Bud
Bud9051 is online now   Reply With Quote
Old 01-09-2017, 02:14 PM   #6
Rewards Points: 18
If you can tolerate a screw hole in the board, drill in a drywall screw near the nails, and use the claw of your hammer to pull up on the screw and thereby, the board.
Sent from my LG-D415 using Tapatalk
jeffmattero76 is offline   Reply With Quote
Old 01-09-2017, 02:50 PM   #7
Rav
Rewards Points: 884
These are all great ideas. I hadn't thought of punching the nails through the board. I already have nail punches but didn't know about pin punches. I think I'm going to try starting each nail with a nail set punch to create an about 1/8" deep hole, then switch to a pin punch to drive the nail the rest of the way down. The pin punch will prevent making too wide a hole like the tapered nail punch would. I'll let you know how this works.
Bud: We do have a basement, which has already been air sealed (blown-in insulation capped with rigid foam board, and expanding foam).
Old 01-09-2017, 07:14 PM   #8
Rav
Rewards Points: 884
OP here. Success! After starting the hole with a nail set punch, I tried using a 3/32" pin punch, which bent fairly quickly and wasn't working anyway. A 1/8" pin punch worked. There was one particularly ornery nail which I couldn't easily get to from up top, but was able to pry the board up enough that I was able to cut it off with a Dremel from below. Anyway, the board is out now and I have the access I need, and I'll be able to re-install that board when I'm done (with a little wood filler and stain in those small holes).
Thanks so much, everyone! I love these forums!
jeffmattero76 likes this.
The Following User Says Thank You to Rav For This Useful Post:
Gary in WA (01-09-2017)
Remove the controversial board room rusty baker Site Help and Suggestions 26 03-28-2014 12:44 PM
Can you remove large floor tiles without destroying them? Lilion Tiling, ceramics, marble 51 03-08-2014 01:53 PM
Problem with board or thermostat? HoldonLiz HVAC 1 02-18-2014 07:09 PM
HOw to remove Cement Board eadamiec Flooring 8 02-17-2011 08:53 PM
How to remove particle board mortared to plywood? k8park Flooring 1 01-02-2011 07:47 AM
