How To Build/Add A Portico To A Porch - Building & Construction - Page 2 - DIY Chatroom Home Improvement Forum
Old 08-03-2015, 10:44 PM   #16
Rewards Points: 2,264
As far as plans you will probably have to make those up yourself or hire someone to do it.
mae-ling is offline   Reply With Quote
Old 08-03-2015, 10:44 PM   #17
Rewards Points: 996
Originally Posted by mae-ling View Post
With your low roof line as others have said yours will need to tie into the roof not hit the wall you will end up with a T-shaped roof.
something like this?
thats the size right there !
Fix'n it is offline   Reply With Quote
The Following 2 Users Say Thank You to Fix'n it For This Useful Post:
mae-ling (08-03-2015), Ron6519 (08-04-2015)
Old 08-03-2015, 10:47 PM   #18
Originally Posted by sunlightishere View Post
Thank you so much for the reply! I like the portico with the columns. I know one suggestion was to move the entry to the left, can't do that because a couple of feet to the left is the bathroom. Here is a picture of a portico that I hope would work for us.
That would work. Just need to tie it into the roof and not the wall, will have valleys. as my pic above shows
Old 08-04-2015, 03:48 PM   #19
Rewards Points: 948
I like the lines and scale. It appears the truss is dropped, due to the eaves, but the roof could run longer? Sunlight's home may not have enough clearance at the eave, so I think it has to sit at top of wall (or above), but the scale works, the lines are great, and I like the open pediment, craftsman look.
You could build it by raising to the top of wall, extending the wall out (double wall) to create a beam pocket, or alternately create a beam pocket with some sort of applied post/corbel/bracket. If the truss is a true truss, the beams could be decorative, with a ridge brace. The exterior wall would be a flush dormer, which could have glazing. At the grade level you need footings. (That post base could be a veneer, wood frame.) I think it's pretty straightforward. Where's sunlightishere?
Any thoughts from anyone else on how to build it? Other approaches? What about raising it up--anyone like that?
keymaster is offline   Reply With Quote
Old 08-04-2015, 06:01 PM   #20
Rewards Points: 948
Looks like there is a bathroom vent potentially in the way, which you might want to move away from the entry.
How to Properly Support a Sinking Porch hotzpacho Building & Construction 21 07-24-2014 10:30 AM
Adding to Concrete Porch + Steps? 99altrade Building & Construction 8 08-01-2011 01:14 PM
Porch Flooring Recommendation RyanS. Flooring 0 04-16-2011 12:31 PM
How to Winterize Porch subdude Remodeling 0 02-04-2010 10:00 PM
New Concrete Porch (Standing Water) ronbar Building & Construction 7 09-27-2008 07:54 AM
