How To Attach Deck Beam To Posts That Pass Thru Deck To Roof - Building & Construction - DIY Chatroom Home Improvement Forum
Old 10-24-2016, 11:13 AM   #1
Rewards Points: 2
How to attach deck beam to posts that pass thru deck to roof
When my house was built, we envisioned a screened deck with roof. We had the builder put the roof on but not the deck to cut costs. Now I'm planning to put the deck on, and I'm unsure how to attach the beam to the four 6x6 cedar posts holding the roof up.
I know bolting the beam to the side of posts was once acceptable, but is no longer recommended or meets code.
Notching the existing 6x6 posts seems like a bad idea given that the roof is supported by them as well.
Adding a jack stud to the side of the post stretching from beam to concrete footing seems like the strongest solution, but not the most aesthetically appealing. Also, the concrete pillars at the top are not very wide and the existing 6x6 are not centered, so jack stud would be on very edge of concrete if at all.
Are there metal fasteners that would help out here?
Also, the beam (deck width) is 24 feet, so I will need to splice the beam since the longest 2x12's I can find are 18 feet.
tim4870 is offline   Reply With Quote
Old 10-24-2016, 11:22 AM   #2
JUSTA MEMBER
Rewards Points: 3,772
Re: How to attach deck beam to posts that pass thru deck to roof
Simpson "strongtie", makes metal brackets for this.
And Menard's tells me that they can special order lumber up to 32' .
Have you tried a Menard's?
ED
de-nagorg is offline   Reply With Quote
Tags
beam , deck
Clear (see thru) roof over second story deck baigr50 Building & Construction 0 04-16-2014 03:15 PM
Is it safe to build a roof over my Hawai'i deck? ModelM2HB Building & Construction 11 07-03-2012 06:22 PM
Insulating flat roof deck paredown Insulation 0 05-15-2012 04:33 PM
Another Deck Question...Gable Roof Post Placement Issues. mgh-pa Building & Construction 2 06-02-2011 06:26 AM
Flat roof questions, advice, ballpark estimate JerryH Roofing/Siding 18 11-07-2008 04:08 PM
